Results 1 to 3 of 3
    Jun 2010
    RS Sektor RL solo air 120mm???
    Does anyone know if the RockShox sektor solo air can be spaced down to 120mm? I know it can be spacer to 130mm but will the extra 10mm spacer cause any problems?
    I have a frame that takes a 120mm max travel fork (On One Inbred) and a Sektor I would like to use.
    thanks!!
    Reputation: Fix the Spade's Avatar
    It's fine.
    If you bought the retail Solo air RL it should come with three 10mm travel spacers in the box, using all three gets you 120mm travel. If you have an OE one you can order the spacers from Rockshox.
    Hi, there are 130mm versions of the Sektor for cheap on Ebay.
    ROCK SHOX SEKTOR TK 26" 15mm Thru Axle Solo Air 130mm
    Can these be easily converted to 150mm? Seems they are often reduced from 150mm to meet a bikes requirements.
    Thanks,
    John
Hot Deals
Contests
Latest Mountain Bike Articles
