Results 1 to 30 of 30
Thread: RS Reba popped
    RS Reba popped
    On my ride this morning I came to the bottom of a hill and heard a loud popping sound. I got off my bike and looked around but wasn't able to find anything wrong. So I got back on and finished my ride.
    As soon as I got back to the car I looked down and noticed that the top fork bushing/ring had popped up, exposing the foam ring below. I attached a picture of it below.
    Has anyone else had this happen before? I supposed I can just clean it out, put some more lube on the foam ring and pop it back into place. But I was wondering if there was something more permanent I can do, or if it is a sign that something else is wrong also.
    I have seen this happen before. Why ? The fork was leaking air past the lower air spring seal (o-ring) and pressurized the lowers - enough pressure and pop goes the seal. If the Reba is a Dual Air U-turn you can also lose pressure from the top (positive) chamber which will pressurize the lowers.
    Reputation: Kiwiplague's Avatar
    Had this happen on my Sektor last year, and my brother had it happen to his Rev. Seems to be a common Rockshox issue when the seals in the neg air wear out.
    I don't crash, I just have slightly uncontrolled dismounts!
    May 2012
    Hmmm.
    MTB B'dos
    Reputation: LyNx's Avatar
    Easy fix...... do a service, remove the crappy RS seals, replace with Enduro seals.
    What is the name of the seals that I should look into replacing? And where are they found? I have take apart my fork a few times, mainly to take out travel spacers, but I am having a hard time remembering where the seals for the negative air chamber are found.
    DFMBA.org
    Reputation: MTBeing's Avatar
    Quote Originally Posted by keen View Post
    This very same thing happened to my Reba RS. Lower air was leaking out, into the upper apparently. Blew the seal right off. My lbs suggested sending it to Push for their factory service.
    Sent from my mountain bike while crashing
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    I have a had no issues w/ Rockshox seals in mild condistions, can't speak for those running in muck. That said I have never seen a RS seal just pop out w/o an internal air leak.
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Maybe when you service it you can install the top cap with the fork compressed a bit so there's less pressure to build up? (I don't have this air model, just a thought)
    Quote Originally Posted by Deerhill View Post
    I may give that a try. But if the issue is really because of a leaking seal then it won't make much of a difference.
    What was weird about this is that it happened at the bottom of a hill. I was going slow and doing a fairly tight switchback when it happened. You would have thought it would have happened earlier. I also didn't notice too much of a difference in how it felt, so if it is leaking it is just a slow leak.
    Feb 2010
    Quote Originally Posted by offroadcmpr View Post
    ... because of a leaking seal ...
    I think some of the guys in this thread are getting their seal's confused. The wiper popping off that you experienced is caused by the one of the two air-piston rod negative piston
    o-ring's leaking. It is most likely the o-ring that has the air piston rod move through it. The outer one on the seal head does not move and almost never fails. If you're lowers a run low on splash oil then the air rod will damage the o-ring seal.
    If these o-rings are not leaking, there is now way for there to be sufficient air pressure build up in the lowers to pop the wiper off.
    Put a pump on your neg air piston and see how much air it still has. If its low then pull the fork apart and change the o-ring.
    Keen's right on the money.
    MTB B'dos
    Haven't used an RS fork now in over 4 years, but on the older Rebas I never thought the seals were great (dust/wiper seals that is) so I used the Enduro ones and they worked fantastic, when changing the oil after changing to them for the same amount of riding/time it was always a lot cleaner. The new Fox seals seem to be good, but then again I haven't gone into my F34 yet, so who know how well they actually keep dust out. Yes I ride is very varied conditions from super dry to torrential downpours and everything in between, so my equipment gets a lot of mud so good seals are critical.
    To the OP, what Keen and the others are saying is right and when they say seal, it's actually just o-rings. Rock Shox has great exploded drawings and instruction on their site and I'm fairly certain there's a YouTube video or two floating about describing what happened to your fork - I've had a couple friends forks leak air from the POS into the NEG, which draws the fork into it's travel, but not the other way around.
    Sep 2012
    happened to me 1 week ago with rockshox reba.
    my fault maybe, cause i went off road with lockout on (forgot it)
    MTB B'dos
    Nope, not your fault AT ALL, the MC damper has a blow off valve and even set to the firmest setting it will, and is meant to blow off and let the fork be active in these situations. If it's within warranty, definitely send it in and get them to fix it. I've done exactly what you did on the older Rebas and I did it with my F34 onto square edged, concrete steps and it did what it was supposed to, no ill effects.
    Quote Originally Posted by ins@ne View Post
    Oct 2012
    How old, amount of use, were your forks have before the seals failed?
    I was reading one makers site who recommended a 100 mile full rebuilt on air springs. Is this normal?
    Quote Originally Posted by Gabe63 View Post
    Sure its not 100hr ? Both my Reba Dual Air fork's had air migration problems well before a half season of use.
    Reputation: ColinL's Avatar
    Feb 2012
    I think you may have misread. 100 hours is a typical service interval for rebuild. For most trail riders, this is around 1,000 miles.
    Oct 2012
    Actually I was looking at x-fusions site, I think some of their recommendations are crazy.
    I have to post 2 more times to link...
    Oct 2012
    OK 10 post now, they seem to want you to pull the shock apart every 25 hours?
    Once per month on my Reba uturn I pull the + core and suck in a couple of cc's of gear oil. When the oil no longer appears at the neg valve I add more. Its an 06 with the same seals it came with.
    lean forward
    Feb 2005
    What would be the reason for the wiper to pop on the right damper side? It's happening on a Revelation I just bought.
    Reputation: tune's Avatar
    Could be too much lubrication oil in the lower leg.
    I would guess too much oil also.
    Mine is is a 2011 I bought new about a year ago. I have take it apart a few times on my own, mainly to take out the spacers to increase travel. The last time I took it apart the seals still looked good.
    I came down with the flu, and then with all of the rain Southern California has been getting I haven't had a chance to take it apart. I did get two 45 minutes rides in without any issues. So I am not sure if it was just air that got in the lowers from the last time I took it apart or something else.
    Quote Originally Posted by jaks View Post
    New or 2nd hand? If 2nd hand, it is possible the previous owner did put too much splash oil in the lower legs as mentioned (8ml is all RS recommends). There may also be damper oil leaking into the lower as well if the seals are worn.
    If new, then maybe the factory over-filled the lowers. Drop the lowers and see how much oil drains out.
    Feb 2005
    Thanks, that must be the reason. I believe there's too much splash oil in the lowers taking up too much air volume. One temporary fix that seems to have worked is, I compressed the fork about 3/4 way until air stopped hissing out of the lowers, then I pressed the wiper (dust seal) back into place. The wiper doesn't pop out now, even when I compress the fork fully. It's interesting that the wiper appears to make an air-tight seal against the stanchions for a long time.
    I will check the oil level in the lowers later and make the fix permanent. Thanks all for your suggestions.
    Just bear in mind that if the lowers are over-filled, you will also get hydro-locking of the fork. This is where the oil prevents the fork from reaching it's full travel because fluids, unlike gases, are not able to be compressed. You can check by letting the air out of the spring side and compressing the fork to see how much travel you get.
    Feb 2005
    yeah, I lowered the positive pressure and compressed the fork fully while testing after my quick fix. I guess there's a point where the lowers are filled enough to build too much air pressure for the wipers, but not so much as to hydrolock.
    Re: RS Reba popped
    Reviving an old thread but FYI if you rebuild the fork and put the negative piston in upside down, the wiper will pop as you inflate the negative chamber
    Sent from my S3 on the way to the trailhead.
    Class Clown
    Reputation: dundundata's Avatar
    Haha good thread
    Hi Keen
    Could you please help? I just got back from a ride this evening and the same thing happened to my 2006 Talas RL, also on the left leg. I take it the Talas has a negative spring that self adjusts to the positive air pressure. Do you think there has been been some leakage from the negative spring into the lower leg in my case? I have just had the fork serviced by the distributor for Fox here in Australia, Sola. The interesting thing was that since servicing, the fork rode like it had a heavier spring in it. I was only using about 30lbs of pressure and it still felt stiff. After the seal blew, it felt great again. Can I just push the seal back down, or should I get it checked for leakage? Cheers mate.
