Results 1 to 3 of 3
    Reputation: Gman086's Avatar
    RS Pike rebound shaft leaking out adjuster hole; Also convert to 150mm possible?
    As title states. I'm guessing there is no fix other than to get a whole new shaft? Are these even available anymore for the 2007 Pikes? Anyone have one for parts?
    Would also love to convert from 140 to 150mm coil. Is it possible? Or should I just bite the bullet and get a Sektor? Fork rides smooth tho (has the PUSH damper system) but bike has low BB and really could use the extra clearance.
    Cheers,
    G
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    B A N N E D
    Quote Originally Posted by Gman086 View Post
    Is this what you want: Bikeman RockShox Rebound Damper Seal Head *Check Notes*
    You might just need a new o-ring on the shaft.
    Bikeman RockShox Reba Recon Revo Pike Motion Control Service Kit
    Thanks cobba, yes, that is the shaft. Now that I think about it, PUSH has their piston on top of the shaft. The only way it can be leaking down the inside of the shaft is for the piston head to not be screwed on all the way tightly or cross-threaded. I'll inspect it when I disassemble today.
    Cheers,
    G
  1. lefty terralogic rebound shaft
    By dypeterc in forum Cannondale
    Last Post: 10-21-2012, 05:55 PM
  2. Installing new rebound shaft/plunger?
    By madamfunk in forum Cannondale
    Last Post: 07-20-2011, 04:42 PM
  3. Monarch Plus Rebound Adjuster.
    By deadbolt in forum Shocks and Suspension
    Last Post: 05-16-2011, 09:07 AM
  4. Fox Float RLC - leaking from the adjuster topcap?
    By gotdurt in forum Shocks and Suspension
    Last Post: 03-01-2011, 07:53 PM
  5. how do I fix Manitou Minute rebound shaft?
    By Bugeye in forum Shocks and Suspension
    Last Post: 02-26-2011, 01:27 PM
