Results 1 to 5 of 5
    RS pike 426 u-turn-need adapter for 7" rotor
    i have a pike fork and im trying to find what adapter i need for a hayes 7" rotor.i ordered the 98-18641 adapter but it contacts the rotor.im at a loss.its a 20mm axle as well.what gives?
    i found this PDF and it says i should use a 98-18640 and not the 18641.every site says the 18640 is for standard QR.am i missing something?i have a 6" front adapter that has a more square body to it and it clears just fine.guess im stuck using a 6" rotor.
    http://www.xfactornet.hu/dokok/letol...chart_2006.pdf
    Here's what I use : http://www.blueskycycling.com/produc...-Type-Axle.htm
    The adapter spacing lists QR but that's what the Pike uses even though it has a 20mm axle.
    thanks.thats what i figured.well i guess ill be back on the trail next week then.bluesky shipped that one you listed to me as a replacement for free.
    so in the event i decided to run a 8" front i would use this adapter
