Results 1 to 5 of 5
    AKA Mr.Habanero
    Reputation: panzer103's Avatar
    RS Monarch HV outer air sleeve removal
    Okay, noob question. How do I remove the outer air sleeve to put some rubber bands on a Monarch Plus shock? Im sure its not difficult but on SRAMs website they make it look really hard like almost taking the whole thing apart.
    Please someone help
    Take shock off bike. Slide the O-ring that holds the outer sleeve down. It's just below the sleeve, it kind of blends in. It can be tricky to get something underneath it to get it off. Then slide outer sleeve down and off. That's it.
    Yup, like Scot says, its easy.
    One word on experience with the bands, I have a Monarch Plus and have only been able to fit 3 bands max, anymore and the can has been impossible to get back on, and thats with shock oil or light grease. Someone else has noted before they had no issues.
    Yesterday I decided to use two rows of electrical tape instead of the 3 bands because they weren't taking up enough volume...dh shuttling last night, perfect.
    Mar 2006
    To get the retention o-ring off I grab it with a paper towel and pinch my fingers inward, which I find is a lot easier than trying to pry it out.
    You could probably do it on the bike too if you cut the volume spacers in one spot.
    Dec 2009
    I don't even take the shock off the bike. As long as you can get either top or bottom shock bolt out then you can feed the spacers on. Top is a tight squeeze but can be done. What I do is ride with some spacers sitting on the shock body. Then drop the hv sleeve and feed a few on on drop some off to fine tune the ride. When you've got it right then remove the unwanted spacers from the shock body after the ride.
  1. changing triple xt (M780) outer ring with double xt (M785) outer ring
    By bapski in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-23-2013, 05:15 PM
  2. Yes I know... Monarch RC3 vs Monarch Pluc RC3 vs Vivid air on a NomadC
    By sir_crackien in forum Shocks and Suspension
    Last Post: 02-05-2013, 08:50 AM
  3. Mounting hardware removal RS Monarch Plus
    By Salespunk in forum Shocks and Suspension
    Last Post: 06-29-2012, 08:14 AM
  4. monarch plus bushing removal for rwc bearing
    By slideways666 in forum Shocks and Suspension
    Last Post: 04-20-2012, 05:46 PM
  5. RS Monarch, Monarch Plus, Vivid tune diagram
    By Breal604 in forum Shocks and Suspension
    Last Post: 11-05-2011, 05:15 PM
