Results 1 to 8 of 8
    Feb 2007
    RS Domain 318 coil spring upgrade help!
    what's the ligthest spring upgrade I can use for my 2008 Domain coil 180mm? I am installing this for my wife's bike and I think this spring is still a little hard and she only weighs 110 lbs.
    I AM I AM
    Reputation: ducktape's Avatar
    Domain Coil, less than 140lbs is White Spring 11.4015.179.000
    That's the lowest listed on the Coil Spring Chart off the Sram / Rock Shox website.
    I AM I AM
    Oh and 140lb-160lb is silver (one I'm trying to get for mine)
    and standard is 160lb-180lb red spring.
    Feb 2007
    Quote Originally Posted by ducktape
    got any info where I can buy this online? If not I may just go with my LBS.
    thanks for the info!
    Reputation: Bromine's Avatar
    Reputation: flyxaos's Avatar
    Do you need just the one spring to change the rate in a Domain?
    There is only one spring in the fork. The other leg is only the damper.
    I AM I AM
    Just the one spring, and it was really easy to change out too.
