Results 1 to 5 of 5
    RP3 vs DHX 5.0 air vs Romic
    I have 3 shocks in my toolbox for my Turner 5 spot. I have been riding the RP3 after a short time with the Romic. The Romic is heavy so I put the RP3 on. I haven't gotten the DHX yet and have read alot on it and seems it is a great shock if you can get it dialed in. I weigh in at 220 lbs so for all you experts out there which shock would you ride given the choices.
    Still learning how to keep the rubber side down.
    BMF
    Oct 2007
    It seems like the homer approved option is the RP23 and if you want to do any light freeride or jumps/drops you should drop $6K on a 6" all mountain rig.
    RP3 is similar to RP23 no? In my experience the DW bikes + RP23 are great for trail riding.
    Reputation: glader60's Avatar
    Pushed RP23
    I have a 2007 5Spot. It depends what type of riding you do. I do some racing and allot allot of XC type riding along with some trail thrown in and the best thing I ever did was to get my RP23 pushed with a custom tune for my riding style and weight. I mostly run with the pro-pedal mode switch on. It really removed most of the pedal bob, yet absorbs the small and large hits very well. If I know I nice downhill is coming up, I just switch the pro-pedal off and let her rip down the hill absorbing everything in my path. A custom pushed RP23 is really the best of both worlds. A stock shock is tuned for the average weight rider, which your are not. See If you can find a pushed RP23 for your frame if not buy a used RP23 and send it out to push, This will really transform your bike. It will be much more efficient yet smother riding. You will not be disappointed
    T.W.O.
    Reputation: mimi1885's Avatar
    +1 on push
    What?
    Reputation: mullen119's Avatar
    DHX air or coil?
    I would go with the DHX if its air, but send it to Avalanche to get the SSD damper installed and a custom tune.
Hot Deals
Contests
Latest Mountain Bike Articles
