Results 1 to 3 of 3
    rp23 body eyelet bushings take out/replacement
    I got a Niner Jet 9 RDO 2012 model and it is nice but within the first two weeks the bushings on the rp23 Fox eyelet (the bottom) got huge play in them. Can someone link me on both the tool and bushings for replacement.
    I sense this is going to be a recurring issue so I might as well learn to do it myself.
    Dec 2004
    Go onto ebay. You'll find one there easy.
    Bushing Removal Tools Tool Set 4 Fox RockShox x Fusion Cane Creek Du Eyelet Bush | eBay
    That one works with either a vise or a mallet. There are more expensive ones that can be screwed, unscrewed with a wrench or allen key.
    Intense 951 Evo and Intense Carbine 29
    Reputation: trailbildr's Avatar
    Dec 2004
    This is what I use. Same thing as linked by CR. I use it with a 1/2 ton arbor press.
    Bushing Tool
    1/2 Ton Arbor Press
    A vice and right-sized sockets will work too. I've done that plenty of times as well.
    Maybe replace it with an Enduro needle bearing kit.
    ABOUT RWC SHOCK EYE NEEDLE BEARING KITS
    Good luck.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
  1. Eyelet Bushings for Monarch Rt3 Plus for 08RFX??
    By digthemlows in forum Turner
    Last Post: 03-20-2013, 10:01 AM
  2. Eyelet Bushings
    By rlouder in forum Shocks and Suspension
    Last Post: 10-17-2012, 04:09 PM
  3. Replies: 4
    Last Post: 11-16-2011, 09:22 PM
  4. Fox rp23 bushings for 5.5 EVP
    By jtforester in forum Intense
    Last Post: 10-31-2011, 08:32 PM
  5. Enduro eyelet bearings for RP23 on Spitfire
    By Cable0guy in forum Banshee Bikes
    Last Post: 04-04-2011, 09:50 AM
