Results 1 to 6 of 6
    Rockshox XC2 vs XC30?
    I have a diamondback response xe that needs new forks. I riding rocky and rooty trails that have a few small double jumps. I am looking to spend only $200 because the bike isnt worth enough to put money into. I really need a full suspension bike but i cant afford it so i need to make do. Please help me because i dont know which one would be better. Thanks.
    Reputation: mitzikatzi's Avatar
    The XC 32 is an "air spring" fork a XC 30 has a coil spring.
    Did you buy the bike new? If it has a Suntour fork maybe you could take advantage of the upgrade option/program.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Rogue Exterminator
    Reputation: kjlued's Avatar
    +1 on the Suntour upgrade program.
    The 26" raidon is a much better choice than the 2 listed and can be bought for I think $150.
    Just stick it in granny and start grinding.
    i did buy the bike new from my local DSG. What is this Suntour upgrade program?
    Quote Originally Posted by mitzikatzi View Post
    Not exactly. The XC32 is available with either a coil spring or an air spring. The difference is size. The number stands for the diameter of the upper tubes - XC32 is 32mm, XC30 is 30mm. The XC32 is a stronger, stiffer fork, even with the coil spring.
    Surly Cross Check: fat tire roadie
    Surly LHT: Kid hauler
    On One Inbred: SS 26er
  1. Rock Shox XC30 TK
    By SuperSlow35th in forum Shocks and Suspension
    Last Post: 07-27-2014, 09:23 AM
  2. Rockshox default coil spring for XC30
    By Bourdagespl in forum Beginner's Corner
    Last Post: 05-23-2014, 11:53 AM
  3. rock shox xc30
    By matthew46 in forum Shocks and Suspension
    Last Post: 07-18-2013, 09:31 AM
  4. rockshox xc30 click
    By antflec1990 in forum Shocks and Suspension
    Last Post: 07-03-2013, 02:52 PM
  5. Rock Shox XC30 gold
    By dubbaduba in forum SRAM
    Last Post: 03-27-2013, 02:50 PM
