Rockshox Revelation XX 2012
Hi
I want to buy a new 150mm fork .
How is the 2012 RockShox Revelation XX Dual Piston 150mm ?
I ride trails and soft AM
how is it compare to the Fox Float 150?
the RS is much chiper then the Fox
Thanks,
Hezi
I have tried a few 150mm forks in the last year. I love Rock Shox. Both RS and Marzocchi are way stiffer for 32mm legged forks than Fox- have a look at the crowns with the forks side by side. Fox wins for the complex and very good damper, best small bump too. RS are super easy to work on and you can buy whatever parts you want to have whatever you want. The XX damper is very simple and I would go for RCT3, have not tried one but sure it would be better and have more adjustment options (anyone know what's in there, any shims?). All of the air springs are simple and easy to work on too. Decide you don't like dual pos, swap it for a solo or older dual air- everything and anything is available. Marz is a good all rounder but lags behind both for small bumps. All just my opinion.
- You may not post replies
- You may not edit your posts
Forum Rules
