Results 1 to 6 of 6
    Rockshox Revelation 426 Stuck in Locked Out position
    Hi, Relative newbie to MTB so go easy. My Revelation 426's are stuck - i have hardly any travel in them at all. The Lock out key on the fork turns but has no affect on the forsk at all. Both upper and lower chambers say 120psi ? Any ideas ? Had forks since 2008. Never serviced.
    Reputation: boogenman's Avatar
    Is the fork still fully extended?
    Does the knob turn with out stopping now?
    My first guess would be that the rod snapped and orfice is stuck in the closed position.
    Yes the fork is still fully extended. The lock out knob turns as it used to ... but minimal compression (as if locked out).
    I'm in no position to service the forks myself - would a good bike shop be able to service these or would you recommend sending them away for repair?
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Quote Originally Posted by shep1971 View Post
    It's a Rock Shox, so the only option is to bring it to a LBS. You cannot send directly to RS for repair (last time I checked). A competent bike shop should at least be able to take a quick look and determine what might be the problem.
    Last post - Do you know the typical price of a Revelation 426 full service ?
    Thanks for your help
    aka dan51
    Mar 2005
    Most shops work on a time basis. So it will cost however much it takes them to figure it out and get it fixed.
  1. POLL: Rockshox Revelation RLT Ti DUAL POSITION
    By chinaman in forum Shocks and Suspension
    Last Post: 11-12-2011, 03:45 PM
  2. Rockshox Revelation RLT Ti Dual Position
    By denjen in forum Shocks and Suspension
    Last Post: 08-04-2011, 02:21 PM
  3. '08 F-series 120 RLC stuck in locked out position
    By 92gli in forum Shocks and Suspension
    Last Post: 08-04-2010, 06:37 AM
  4. Replies: 1
    Last Post: 06-28-2009, 05:48 AM
  5. Marathon SL is stuck in teh locked out/compressed position, ideas?
    By wvbiker in forum Shocks and Suspension
    Last Post: 08-27-2006, 01:40 PM
