• 01-12-2013
    RockShox Recon Silver air pump
    I have a 2013 Cobia that has a RockShox Recon Silver Soloair fork. I was wondering if I could use a tire pump on the air pressure side of the fork. If not, how much money is an air pump for the Recon Silver?
  • 01-12-2013
    I'd either take it to your LBS or scope out eBay for one. Can probably score one for ~$20.
  • 01-12-2013
    Aint going to do it with a tire pump.
    I got a giant tire/shock combo pump that does a great job and does fine with the pressures.It basically has a telescoping pump hande you use the bigger part for tires and the smaller one for shocks forks,
