    Reputation: J273's Avatar
    Rockshox pike rebound bolt binding.
    Hi all,
    Ive lower leg serviced and changed the travel on my '13 pikes a fair few times since ive had them with no issues. Last week i went to change the travel from 120 to 130 chagin the air spring but for the life of me i couldnt get the rebound adjuster foot bolt undone it was just spinning freely turning the rod inside.
    I tried everything but it was having non of it. The only way i managed to get the bolt off was by hacksawing the bolt off the bottom of the leg and then using pliers winding the little thread left on off the bottom.
    Ive just managed to get hold of a new rebound adjuster and bolt and gone to fit it but im now finding its binding and will only go in a few mm of thread before it gets stuck. I aslo have another set of pikes and ive tried that bolt and have the same problem. Thing is the threads are fine as if i try threading in the bolt from the other leg that goes in fine with no problems.
    Has anyone had the same problem and any idea as to what the problem could be or how i can fix it?
    Many thanks
    If the problem follows the bolt it's the bolt. Can you chase the threads & try again? Many hardware stores sell those taps for about $5. Might be handy to chase those threade from time to time & anti-seize em.
    1983 Ritchey Everest
    1996 Bianchi Mega Tube ti
    1996 Ibis Mojo Ti
    2012 Ibis Mojo HD
    2015 Kona Process 153
    Yeah run a tap through the damper rod, Iíve had this before
    Thanks both, ive ran a tap through the damper rod and all is fine. Ive rebuilt the forks and they work spot on.
    Thanks again.
  1. Missing screw from Rockshox Pike Rebound Adjuster
    By jazzanova in forum Shocks and Suspension
    Last Post: 08-18-2017, 12:53 PM
  2. Rockshox Pike - need faster rebound
    By kickhorse in forum Shocks and Suspension
    Last Post: 04-29-2015, 11:20 AM
  3. Replies: 3
    Last Post: 09-16-2013, 05:55 AM
  4. Hope Pro 2 142 binding
    By carlhulit in forum Wheels and Tires
    Last Post: 06-16-2011, 09:33 AM
  5. Intermediate to Advanced AM ski/binding/boot recommendations?
    By Sid Nitzerglobin in forum General Discussion
    Last Post: 02-02-2011, 07:25 PM
Members who have read this thread: 24
