Results 1 to 8 of 8
    Mar 2013
    Rockshox Monarch RT3 Service Question
    I would like to take the air can off of my new 2013 Monarch RT3 to ensure the seals are lubed properly but Im not sure if I am able to based on the tools I have. I do not have a schrader valve removal tool and with that being said does anyone know if it is safe for the air can to be unthreaded by just releasing the pressure? Also is it neccessary that the pressure be released from the IFP when only removing the air can?
    Warrior's Society
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by Roundhouse 2200 View Post
    If all you are goin to do is service the air can....you don't need any special tools.
    Push the Schrader valve and let all the air out if the main air chamber.
    Unscrew the air can.......apply light grease to seal....reinstall.
    You shouldn't have to touch the IFP or piston.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Reputation: ktm520's Avatar
    ^^ Do not release the IFP pressure. Release the spring pressure while it's still on the bike and break the can loose before you remove it from the frame. Should be hand tight.
    Mar 2013
    Thank you both very much!
    Oct 2011
    Re: Rockshox Monarch RT3 Service Question
    I was wondering about this myself. So does the shock need a specific amount of oil in the main can area? Any oil recommendations?
    Sent from my DROID BIONIC using Tapatalk 2
    Oct 2011
    I just found the service manual on the rock shox website.
    0.3 mL of maxima maxum4 extra 15w 50 if anyone else is interested.
    Trial
    Reputation: trailbildr's Avatar
    Dec 2004
    And if you have a pre-'13 Monarch, you have the o-ring lower air seal which will probably leak in the coming months. Call have your dealer call RockShox and ask for the updated quad seal for the Monarch.
    Good pics on the SRAM service site.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Quote Originally Posted by trailbildr View Post
    mk
    Are you referring to the IFP seal? Sounds right since mine has leaked.
  1. Rockshox lyric RC2DH service - oil replacement question
    By BicicletaBob in forum Shocks and Suspension
    Last Post: 05-20-2014, 02:24 AM
  2. Rockshox Monarch 4.2
    By Madcow38 in forum Shocks and Suspension
    Last Post: 11-24-2013, 09:43 AM
  3. New to me rockshox monarch rt3
    By kikoraa in forum Shocks and Suspension
    Last Post: 02-12-2013, 12:04 PM
  4. RockShox Monarch R
    By ehigh in forum Shocks and Suspension
    Last Post: 04-25-2011, 08:32 PM
  5. RockShox Monarch Plus RC3
    By MobileMech in forum Shocks and Suspension
    Last Post: 02-08-2011, 11:40 PM
