Results 1 to 35 of 35
    Mar 2013
    Rockshox Monarch RT3 noise. Please help
    My new 2013 rockshox monarch rt3 shock has about 2 rides on it and it has a "squeaky toy noise" upon compression and rebound. I don't understand, it is brand new only had it for a week and it makes this noise. It is very annoying and for close to $300 I dont think it should sound like that. Doe's anyone have a solution for this problem???
    May 2010
    does it make a wooshing sound?
    Reputation: pulser's Avatar
    Dec 2004
    Take the shock off and turn it upside down so the gold part that slides in and out of the body is pointing up. Then take a little lube and put it around the seal. Leave it sit for a few hours to soak in. Its just a dry seal
    Rockshox Monarch RT3 NOISE problem VIDEO!
    Rockshox couldn't fix mine...Eventually I was sent a new shock under warranty.
    Mar 2013
    Do you mean the seal on the piston that seals the air can or the piston glide ring in the damper body?
    Mar 2013
    Yes it sounds just like the video that was posted but somewhat quieter. I saw somewhere that there was a surface finish problem on the damper body for the 2012 version and earlier but I figured that it would have been fixed by now if that was the problem.
    Dec 2004
    Quote Originally Posted by Roundhouse 2200 View Post
    My shock did that too but when I but a little lube around the seal it stopped. I don't know if its the glide ring or the piston seal. I ended up having the shock rebuilt by Dirtlabs becasue the damper started to leak oil and I didn't have time for Sram to do it.
    Mar 2013
    Was this the seal you lubed up or did you lube the piston seal that keeps air in the air can?
    Dec 2004
    The piston seal. I didn't take the shock apart. I just put it in a vice to hold it upright. And then dropped lube around the seal.
    Mar 2013
    I will have to give this a try and see if it works. Im guessing that the seals might not have been lubed up properly at the factory. Any recommended lube that is ok for rubber seals?
    Dec 2004
    I'm told they ship shocks and forks rather dry. I usually open them up and lube every thing right away. I didn't with this shock becasue of the second air chamber and I don't have the adapter to fill it. I just used an Teflon based lube I think it was finshline.
    Mar 2013
    The only thing that I have on hand at the moment is some "white lightning" all purpose chain lube. I wonder if that will work. Also will the seals burn up and not work properly if I continue to ride without them being lubed well enough?
    May 2013
    My shock does the same exact thing. Started about 2 hours into my first ride on my new bike last week. Drives me nuts. Called sram and they told me to go to my local dealer where i bought the bike. Went to the bike shop and they say its normal just to lube the stansion. I lubed it and it didnt do a thing. Not happy, when you spend big $ on a bike you expect it to work and not sound like a dogs chew toy... Looks like ill be buying a fox float ctd and selling the monarch on craigslist... Sucks.
    Mar 2013
    A lot of people seem to say that the noise is normal but it just seems like this problem should be any easier fix than it is made out to be. When the noise starts and gets worse as the shock is used it makes me think that the seals are not greased properly and arent sliding smoothly.
    May 2013
    I think im going to take it apart and see if lubing it works. Ill report my findings.
    Mar 2013
    I think after you take the air can off it would be a good idea to remount the shock on the bike and see if it still makes the noise without the air can. If it still sounds like a dogs squeaky toy at least we will know that its not a lubrication issue.
    As stated in a previous thread:
    "That sound you're hearing is from the damping piston glide ring running on the inside of the body of the shock. It's making the sound due to a surface finish problem. Other than replacing the body of the shock, there is no fix"
    May 2013
    Quote Originally Posted by keen View Post
    If thats the case why would it not sound like that right off the bat? Something had to change between the time i bought the bike and the time it started squeaking. I would suspect rockshox should be held liable and fix the issue with a new finish and replace all of the defective shocks. I think its Bull that my brand new bike sounds like a toy. It really drives me nuts out riding all i can think about is the damn squeaking.
    I still dont understand why it didnt sound like this from the getgo if its a finish problem. I guess my next phone call will be to trek asking them for a replacement/upgrade to a fox float ctd.
    Quote Originally Posted by Supafly9 View Post
    I didn't notice anything until a couple rides. I initially thought my air can seals were dry but lube didn't help. I stumbled across this thread : Rockshox Monarch RT3 NOISE problem VIDEO! and decided to call SRAM. SRAM's usual response "take it back to your dealer" When I mentioned what I had read about an internal problem they said never heard of this. Two weeks later my dealer called to say the shock was repaired. Installed and within a half dozen cycles the noise was back! I could tell the shock had been disassembled because the rebound knob felt stiffer. In the end my dealer got me a new shock, they said it took a bit of coaxing. I didn't even mount the new shock as I sold it & went to a Fox.
    May 2013
    Damn, that doesnt sound too promising for the rest of us doomed monarch owners. Looks like ill be wasting ~375$ for a float then. Im still going to dissasemble mine and see if i can fix it. Why not right, i've got nothing to loose.
    Mar 2013
    Absolutely, I really hope the lube does the trick even though the odds seem against it. When I ride the shock a little and it warms up it sounds like the squeaky noise gets just a little bit better. That makes me think when the seals get warm with friction they get softer and run along the surface of the shock more smoothly.
    Jun 2013
    Hay all I have a big problem really need advice. I've just got my new 2013 nukeproof mega AM frame with 2013 rock shox monarch plus. It is makeing a clunk noise when I put in air . I've not Evan rode this yet . At 170psi it is a very loud clunk . At 50psi the noise is gone . Wtf ??? I'm dieing to go ride my new toy but I'm not going to risk rideing and doing damage . Any help would be great I'm at a loss
    May 2010
    There is something wrong with the shock it shouldn't make that noise don't ride call dealer that shock came from or bike company
    Jun 2013
    Thanks sheddin22 I've not rode it since I brought it which is a shame. Sending it off Monday to FISHER for repair or replacment .
    Just bought a closeout 2013 giant anthem x advanced 1 one with the Monarch Rl and after one ride I started hearing that squeaking plastic toy sound that most people seems to have with the RS monarch. Took it back to the lbs, new seals, rebuilt shock and now it seems to make a even more distinct sound with the new seals. Should I run back to the lbs and perhaps better lube the seals (which I suspect wasn't done correctly) ?
    Is the noise just a sign that the seals might be running a bit dry or like someone suggested it's a bigger issue, like the poor finish , and I should as for a replacement ?
    Has anyone just tried re-lubricating the seals and experienced an improvement in the sound department ?
    Reputation: trailbildr's Avatar
    Dec 2004
    There are two things to think about with these rear shocks.
    First: Air can
    The air can unscrews and can be easily serviced, checked or whatever as long as you let the air out first. There is very little that can make noise as the only things that are really moving are the two quad seals sliding over the damper body. Bath oil in there keeps those lubed and usually don't make noise. This can be checked and fixed in 3-5 minutes even with the shock on the bike.
    Second: Damper body
    Once you remove the rear shock from the bike and remove the air can, you are looking at the damper which is full of oil for damping (rebound and compression) along with your compression and rebound shim stacks. There is a PTFE glide ring and a charge of air (nitrogen) for the IFP. The IFP keeps the rear shock at its static eye to eye and forces the oil from the remote reservoir back into the damper body.
    The noise that you are experiencing is likely coming from the damper body, way inside the rear shock. If your rebound and compression circuits are working, you don't have a 'real' problem. I say 'real' because there is no compromise to the operation. Noise sucks but RockShox might consider noise within spec, especially if it's not manifesting itself in any non-audible ways.
    No external lube will get anywhere near where the noise is manifesting. It's hard to say what RockShox would say about it. Remember, when you call SRAM (or, rather, when your BIKE shop calls) they are getting SRAM customer service, not RockShox experts. They are great, to be sure, but I regularly get over their heads quickly with pointed questions.
    Some suspension shops, on the other hand, have a more direct line to RockShox out in COS. They may not be able to get a warranty approved through COS, but they can at least figure out what is going on.
    I don't know what is causing it but there is a good chance that the above-listed problem is it. Internal coating on the damper body... I haven't seen any problems.
    Good luck. Report back.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Jun 2013
    Hay I had mine TF tuned a while back now . TF put blue lube inside to help keep it running sweet . This lube would build up on the shaft outside the shock it's not a problem but now the stuff has gone and shock runs dry . How can I top this up ???? I can remove the outer sleeve to the shock no problem so how do I open the main one ? Is it simple ? Just open it up pop more blue lube in and close ? I don't have to worry about nitro do I ?
    Dec 2004
    Read it again.
    The air can unscrews and you can add the air seal lube right into the air can. This is basic service that needs to happen regularly. The damper service is where the IFP is and you don't need to do that nearly as often. Just open the can, pour in 5cc and reinstall get it back up to pressure.
    mk
    TrailWerks Cyclery
    Jun 2013
    Quote Originally Posted by trailbildr View Post
    Read it again.
    mk
    thanks I've just tried unscrewing it by hand and it's solid . I've seen a rubber band kind of tool to do this but I don't have one any tricks on how to unscrew ?
    Dec 2004
    Strap wrench from an auto parts store. It's used to remove oil filters.
    mk
    TrailWerks Cyclery
    Dec 2009
    Monarchs are good shocks but unlike Fox they only come with a lick of grease as lube in the air can. I always remove the air can from new and add some slick honey or similar grease. You can't use oil like fox as the seal is not designed to hold it.
    As for the video, sounds like a teflon back up ring is proud and is rubbing, possibly lack of lube too. That is always amplified on a carbon frame though.
    Quote Originally Posted by gvs_nz View Post
    Sounds like a fairly quick fix. Any other grease other than the one you're suggesting I could try ? If it works I suspect I'll have to repeat the process frequently to keep the shock quiet.
    Should I let my LBS deal with Sram customer service first before trying anything myself though, I feel like it would be the perfect excuse for Sram to not honor their warranty if they see any sort of aftermarket grease on the shock ?
    Reputation: ktm520's Avatar
    I agree that they come with insufficient lube from the factory, but you can most definitely put oil in the can and I would highly recommend it. Even the newer RS service manuals recommend putting oil in the can, although it is a ridiculously small amount, something like 0.2cc. I don't measure it, but probably use about 1-2cc. Once the shock stops leaving a film of oil on the damper body, its time for another squirt of oil.
    Dec 2004
    SRAM already knows if they are going to take your rear shock back before your shop calls. They have policies and stuff. They don't care if they see stuff inside. Once they get it on the way back to HQ, it gets fixed. Their warranty process isn't that seamless or linear.
    If this isn't a known issue, you'll likely be kicked down the road. I don't think you have an issue either as it's not DOING anything other than making a noise. But that's just me. Would I take a shock back that *I* worked on due to noise? Probably. As a matter of fact, I have.
    I put a few ccs of oil in my Monarch Plus air can too! I just use Float fluid cuz I has gobs of the stuff around. I think any oil work work as it just keeps the seals lubed. RockShox BlackBox guys use the Parker O-Lube stuff on a lot of seals.
    mk
    TrailWerks Cyclery
    Jun 2013
    mk
    hay I've got a strap wrench at last . Ok so let air out and used strap wrench and loosened the can all while the shock is on the bike. Pull air sleeve down and poped lube in . Same stuff as TF put in my shock when it was tuned . So I poped the lube inside just on top of the red thingy bob and put air can back together and filled back my psi . Job done . Did I do it right ?
  1. Rockshox Monarch RT3 NOISE problem VIDEO!
    By TheYoungConnoisseur in forum Shocks and Suspension
    Last Post: 04-14-2016, 11:26 AM
  2. RockShox Monarch Plus
    By pat656 in forum Ibis
    Last Post: 12-03-2014, 06:03 PM
  3. Rockshox Silver TK Noise
    By zxpwr350 in forum Shocks and Suspension
    Last Post: 04-19-2013, 02:06 PM
  4. New to me rockshox monarch rt3
    By kikoraa in forum Shocks and Suspension
    Last Post: 02-12-2013, 12:04 PM
  5. RockShox Monarch RT3
    By wpodriver in forum Shocks and Suspension
    Last Post: 02-09-2012, 04:31 PM
Members who have read this thread: 4
