Results 1 to 5 of 5
    Last word is all yours...
    Reputation: r1de's Avatar
    RockShox Lyrik IS 2-Step - travel adjustment problem
    The fork is only 1 year old, but I've put a fair number of miles on it. Pressure seems right, travels through range well. However, the min/max travel adjustment doesn't seem to be holding anymore (it has been fine up until recently). When I set the knob for min travel (115) and compress the fork, it doesn't really want to stay compressed in the 115 range. When I switch the knob back to max travel (160), it only lengthens by a few mm.
    Any suggestions?
    -bp
    Turns out the 2step cartridge was bad; had it replaced under warranty and it seems okay now.
    -bp
    Dec 2011
    Hello,i have this problem now.You mean the top cap that adjusts the travel?
    Yeah, the adjuster on the top of the left stanchion. For me, the "min" position no longer held in place. It was fixed by replacing the cartridge.
    -bp
    Dec 2011
    Untill now its ok??I will change it,i was thinking that the top cap must be because i have done the service and everything was fine inside the suspension.
  1. Rockshox Lyrik 2 Step Air - need some help
    By montejr in forum Shocks and Suspension
    Last Post: 01-23-2012, 10:58 AM
  2. Rock Shox Lyrik 2 step travel adjustment not working
    By Darkstar187 in forum Shocks and Suspension
    Last Post: 11-19-2010, 09:41 AM
  3. 2010 rockshox lyrik 2 step
    By hernluis in forum Downhill - Freeride
    Last Post: 10-05-2010, 06:13 PM
  4. 2009 Rockshox Lyrik 2-Step Air
    By LittleSanchez in forum Turner
    Last Post: 09-15-2009, 12:42 AM
  5. How is the 2009 RockShox Lyrik 2-Step???
    By JohnnyG 1970 in forum Shocks and Suspension
    Last Post: 02-03-2009, 04:57 PM
