Results 1 to 26 of 26
    RockShox 15mm axle
    My wife's bike has a Rockshox Sektor on it and it has one of the expanding collet axle like this one
    Me and Her both hate this axle as the corners of the area you use to loosen or tighten it have gotten bent up and sharp, as we have to take the front wheel off every time we go ride as we use fork up roof rack trays.
    So now on to the question can we replace it with the new style one like this one:
    ******UPDATE****** The axle Part Number from when this was originally talked about, and figured out has changed to 00.4318.005.006 the link for the part on BTI's Website is BTI | Rock Shox Maxle-Ultimate Road Q/R 15x100mm T-A kit******UPDATE******
    i dont think you can, just by looking at the picture. it looks like the older style is tapered where it seats to the dropouts, where the newer style looks to be flat.
    Reputation: honns's Avatar
    I worry about what darkstar says, but it claims to be a drop in replacement for the expanding type. Soon enough my old style axle is going to bend too much to be usable and I'll try out the new B1 type, but until then I'm hoping someone else will take the plunge!
    BTI | Rock Shox Maxle-Lite Q/R 15mm T-A kit, 11-15
    We may end up being the first to take the plunge, I am sort of hoping that someone owns a pike and also has access to the sektor that could try it out without having to spend the money.
    Reputation: Kiwiplague's Avatar
    According to the Rockshox 2014 spare parts catalogue, where the maxle is listed for the Pike, it says "Maxle Lite 15mm Black (compatible with all RockShox 15mm ta)", so it looks like you can use it.
    Link - http://cdn.sram.com/cdn/farfuture/_v...pc_rev_a_0.pdf
    Page 46 shows the image of the new maxle and page 48 has the relevant part number (00.4318.005.001).
    I don't crash, I just have slightly uncontrolled dismounts!
    So I managed to stumble across someone out on the trail that had a pike so I asked if i could try his axle in my wife's fork and he said sure and let me try and everything seemed to fit so we ordered one from the local bike shop.
    I picked it up and installed it today and everything fits fine and here is a picture.
    What does it look like from the side, does it sit flush?
    Fat-tired Roadie
    Nov 2007
    Good to hear.
    I ordered one for my Reba recently. It's funny, sometimes I feel like the best upgrades are always small, usability-related things.
    Reputation: ewarnerusa's Avatar
    Excellent. Same conundrum here and I want to replace my older style 15mm front maxle.
    Resurrecting and old thread since I've just run into a problem trying to upgrade to the new lever. I was sent a 00.4318.005.001 Maxle Ultimate which appears too long to replace my 15x100 Maxle Lite. Did I get sent the wrong part or do I need a different part number?
    What fork are you currently running? The Maxle ultimate is for the Pike RCT3/RC/DJ and RS-1 forks.
    Looks like they may have sent you the Boost 15 x 110 version.
    Quote Originally Posted by mmckechnie View Post
    I have to agree with this statement, as the one they sent you is about 10mm longer, i wouldn't contact whoever you got it from.
    Ok, thanks for the feedback since I'm also looking for the new lever (version B?) 15x100 Maxle Lite 15mm that the OP found. Can anyone confirm the correct part number?
    Quote Originally Posted by CharT View Post
    this is what i had ordered
    you can use this link to find a bikeshop near you that can order from BTI
    BTI | Store Locator
    Ah upon further research it looks like they changed the part number
    I think this might be the one you want
    here are the search results for maxle on bti
    BTI | products matching "maxle"
    I contacted the seller and they reiterated that 00.4318.005.001 is for Pike/RS1 only. It's possible that RockShox changed part numbers and they certainly changed the name from Maxle Lite to Maxle Ultimate. The Maxle Lite XC, which is what I originally have, seems to have a newer version called Maxle Lite 15mm.
    I'll check the dimensions of my Maxle against the 00.4318.005.006 part that you posted. The first difference that stands out to me is the threaded section of 12mm on the road Maxle versus 9mm on the off-road applications.
    Okay, I just received 00.4318.005.006 which looks like the correct replacement with the new style lever. So, maybe Rockshox changed their part numbers or whatever, but 00.4318.005.001 is NOT the replacement for the old 00.4318.005.002 Maxle Lite. Order 00.4318.005.006 also described as "Maxle-Ultimate Road 15x100mm."
    Awsome, enjoy the new axle, I will put an update in the original post so that no one else makes the same mistake. Shame they made it so complicated.
    Nov 2014
    Bumping this and thanking the OP. Mine is shredded on a 2014 Specialized Comp. Going to order one of these today.
    Am trying to clarify this. I need a new skewer for a 2016 15x100 pike. the sram parts pdf still specifies 00.4318.005.001 15x100 ultimate. The only difference i can see in spec is the 148mm total length compared to 125mm for the 4318.005.006 15x100 maxle lite / ultimate-road. Since both have same 15x100mm hub, all i can deduce is the fork lower mounts are thicker on the pike and RS-1? The 2016 pike measures 24mm per side (and that makes up the 148mm).
    Could someone please measure a sector/revelation or 2014/2015 pike to see if it's less than 24mm? (the lowers that the axle goes through). I can only assume they're 12.5mm thick to make up the 125mm total width.
    If i am correct.. 2016 (and maybe earlier) pike and rs-1 owners cannot use a 00.4318.005.006 ultimate road skewer as it's too short.
    -Mark
    Oct 2010
    My 2016 Pike and my 2014/15 SID both use the same length Maxle. I actually went with SRAM through bolt,"Maxle Stealth", instead of 15QR, but I ordered both the same length. Which was 148mm. The boost is 158mm. I also ordered the Bluto version at 198mm. These dimensions are from Universal Cycles website where I bought them.
    since 4/10/2009
    Reputation: Harold's Avatar
    I went with a dt swiss rws to replace my crappy maxle lite. Noticeably stiffened my bluto.
    Dec 2012
    Thanks to this thread.
    Life saver!!!
    I recently damaged my TA QR on my Marzocchi 350NCR -- and Marzocchi replacements parts are very hard to come by in my area.
    I did not realize that RS offered a longer TA on the PIKE until I read it here.
    So as on the pics below, the MARZ Axle fits perfectly on the PIKE, and the MAXLE fits perfectly on the MARZ!!!
    And you have saved me, because I will be able to use the Marz fork for saturday's race!!
    RockShox 15mm axle-12421932_10154040623109600_636639841_o.jpgRockShox 15mm axle-12528714_10154040622954600_235226302_o.jpg
    Apr 2015
    Quote Originally Posted by Harold View Post
    I have a 2015 RockShox SID XX World Cup 15x100 and want to get rid of the crap Maxle. Want a DT Swiss RWS to go with my DT wheels but was told it wouldn't work.
    Can you provide some guidance as to which one to go with, which one you went with.
    since 4/10/2009
    Quote Originally Posted by JuanGrande View Post
    There was only one option available in the size I needed. 15x150mm. It was made to fit the Rockshox Bluto fork. I bought it. It worked.
    You need to check the dimensions of exactly what you need and match them up to a replacement. Axle diameter, axle length, thread pitch, and possibly even the length of the threaded portion.
    But also note that not all axles work in all cases. I have since replaced the Rockshox Bluto fork with a Wren suspension fork. I cannot use the DT RWS in the Wren. The length, axle diameter, and even the thread pitch all match up, actually. What doesn't work is that the fork is inverted and its interface with the axle requires a hemispherical bit at each end of the axle. There is a nut on one side that fits the RWS, but the lever end of the RWS lacks this bit. I MIGHT be able to source a washer to make it work. Which is why I still have the RWS when I sold the fork months ago.
  1. Replies: 5
    Last Post: 06-24-2015, 10:25 PM
  2. Replies: 0
    Last Post: 03-08-2014, 02:38 PM
  3. Stan's 3.30 15mm Hub/Rockshox axle and fork compatibilty
    By rustyjacksons in forum Wheels and Tires
    Last Post: 02-09-2014, 03:11 PM
  4. Yay! 160mm Rockshox Pike. Booo! 15mm Axle.
    By juan_speeder in forum 29er Bikes
    Last Post: 04-04-2013, 03:30 PM
  5. 9mm QR vs. 15mm thru-axle
    By awai04 in forum Shocks and Suspension
    Last Post: 02-27-2013, 02:29 PM
Members who have read this thread: 4
