Results 1 to 3 of 3
    Nov 2008
    Caution;  Merge;  Workers Ahead! Rock Shox Solo Air problem (argyle 409) - "idle travel"?
    Hey guys!
    I have quite a big problem with my RS Argyle 409 - actually, with its solo air spring.
    First of all, I have (from some months) sth like "idle travel" - I mean, by first 4mm of its travel, the upper legs seem to be "loose" in lower ones - just like there is no spring inside. I have dissasambled it one day and figured out that this seems to be normal. But that's only annoying, so - never mind.
    But, few days ago (after changing o-rings, but I don't think it can affect), something happend to my Argyle - this "play" is getting bigger, so that I can push it almost all travel down without using almost any force - only to move the fork, just like there is no spring inside. It doesn't rebound itself, I have to pull my bar up. When I compress fork quickly - I can feel ~1cm of this "idle travel", than I hear a single nock and it works normally all the way down.
    What can it be caused by and how can I repair it?
    Maybe this is something with this "valve" which is between positive and negative air chamber (I mean it may not close when compressing a fork).
    I have made an video to show you situation better (yea, I know how cute my english is... hope you'll understand sth):
    http://img12.imageshack.us/i/1004609.mp4/
    Can you help me? Thanks for every advise (I hope there is someone who is well versed in rock shox).
    Cheers,
    Brooce
    Mar 2005
    Quote Originally Posted by Brooce
    This is exactly your problem. The valve is sticking open for some reason. The 'wave washer' is often to blame. Go here: http://www.sram.com/en/service/rocks...ch_manuals.php
    and find the tech manual in your language. Read through the solo air service pages.
    Nov 2008
    Quote Originally Posted by davep
    THANK YOU!!!!!!!!!!!!
    That REALLY may be it!!!! I have even not thinked about it, but it seems to be obvious!!
    tommorow I'm going to shop for a new washer. Hope that will solve problems with my argyle!
