I have jsut serviced my 2003 rock shox pilot xc and upagraded to 100mm travel insted of the original 80 mm set up. The feeling is much better , but I can see some oil leaking out of the top of the lower tubes, along the upper tubes. I have put the recommended amount of oil.Does that mean that a seal is weak, I put too much oil, or is it normal after it has just been serviced?
I plan on having it checked up at the LBS . How much would they charge? What would be the next recommended front suspension upgrade ? Marzocchi MX?( I am 175 pds and ride a 2003 XL tassajara.) I am moving to Africa (Kenya) so I need a low maintenance reliable one.
