Results 1 to 3 of 3
    Rock Shox Jett XC
    I just ended up with a Rock Shox Jett XC long travel fork and want to replace the aging fork on my wife's bike. The only issue I can see with it is that the Jett does not have that whatchamacallit that secures the cantelever brake cable end cap. Yeah, I know, canti's are passe, but that is what is on the bike, and since they are integrated with the shifters (thankyoushimano), I'm loathe to change them both out.
    There *is* a hole in the fork's brace, so I'm assuming I can buy something to put in there to hold the brake cables.
    Anybody know what I'm talking about? Help a guy trying to give his wife a better ride.
    fsr
    fsr is offline
    whachamacallit
    That fork was designed for V brakes but i'm sure there is an adaptor out there for it. Try asking at your lbs about it.Good luck FSR.
    Reputation: logbiter's Avatar
    headset spacer w/ cable stop
    should be available through your local bike shop. I've seen them for both threaded and threadless headsets, so you should be covered there. That would be an easier solution than trying to find a stop to fit onto the fork.
    good luck!
    Serge
    Quote Originally Posted by dethrok!
  1. Rock Shox Psylo XC heavy springs
    By biking_2003 in forum Shocks and Suspension
    Last Post: 10-20-2004, 08:21 PM
  2. judy rock shox TT 2004 model $ 110-Good?
    By zach in forum Downhill - Freeride
    Last Post: 05-25-2004, 06:45 PM
  3. 2003 Rock Shox Psylo Race
    By NRSAirDriver in forum Shocks and Suspension
    Last Post: 03-22-2004, 08:48 PM
  4. Rock Shox Discs?
    By Threesticks in forum Brake Time
    Last Post: 03-18-2004, 08:00 PM
  5. Rock Shox disc rotor with different calipers?
    By bhutata in forum Brake Time
    Last Post: 03-15-2004, 04:18 AM
