Results 1 to 5 of 5
    Rock Shox Indy Sl
    IVE HAD MY TREK 8000 SINCE 98, BUT LOST THE ORIGINAL DATA/ COMPONENT SHEETS FOR THE INDY SL , AS I WANT TO CLEAN AND RE-LUBRICATE THEM MYSELF , CAN ANYONE LET ME NO IF ITS EASY TO DO AND WHAT IS THE PROCESS
    CHEERS- SKIN FROM LONDON
    Former Bike Wrench
    Its easy if you have the right tool, a really long (like a foot plus) 5mm allen wrench or a long extender bar attached to a 5mm allen.
    You simply remove the top caps and spring/MCU stack to access the bolts at the bottom of the legs. Unscrew the legs and it will come apart.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    This assumes the elastomers aren't fried and its therefore worth the time to overhaul the fork.
    I don't post to generate business for myself or make like I'm better than sliced bread
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    I believe the inner allen bolt head that holds the stachions to the legs is 8mm. Frankly the Indy series has to be one of the flexiest, wimpiest forks in existence. It does, however, make an awesome commuter bike fork. I put some Englund air cartridges in mine a long time ago, and they work excellently...very light and actually has some damping. If you plan on riding this fork off road to any real degree...don't.
    Former Bike Wrench
    Nope, its 5mm
    Quote Originally Posted by TNC
    It's not 8mm...its 5mm, I still have the homemade tool in my tool box (a 5mm allen that I cut off before the bend then JB Welded into a 5mm socket).
    But I agree, it was one flexy fork (as were the Mags and Quadras)
