Thread: Rock shox
    Jan 2013
    Rock shox
    Rock shox 2012 xc32 TK for 139$
    Model XC32 TK
    Application/Type XC
    Travel 100MM
    Wheel Size 26"
    Axle Type 9mm QR lower leg
    Spring Type Coil
    Lockout Yes
    Adjustments Rebound: External Adjust
    Rebound Control Yes
    Crown Forged, pocketed 6061 T-6 aluminum crown
    Steer Tube Diameter 1 1/8"
    Steer Tube Material Aluminum
    Steer Tube Length (Uncut) 10.2 inches, 259.08mm
    Brake Mount Type Rim/Disc
    In- House Weight 4.82 lbs, 2.18 kg
    Warranty 2 year manufacturer's warranty
    OR
    2011 rock shox recon Silver R. 99$
    Model RockShox Recon Silver R
    Application All Mountain / Cross Country
    Travel 100mm
    Compression No
    Preload Spring via Preload
    Rebound External Rebound
    Steer Tube Material 4130 Steel
    Color Diffusion Black
    In-House Weight 4.93Lbs/2230 grams
    Brake Max 210mm Disc / Rim
    Axle 9mm Open Dropout
    Lockout No
    your suggestions are extremely appreciated. i just ride trails...up and back down sort of thing. bike is older Raliegh m80 with a manitou six fork on it...that barely absorbs anything. thinking new cheaper end fork to get me by until new bike.
    Jan 2013
    Really??? Anyone???
    I would choose recon, is supose to be a model above XC
    "El Whatever"
    Reputation: Warp's Avatar
    I'd go with the xc32. It has aluminum stanchions, hence lighter and probably you could slap a better damper.
    Check my Site
