    Apr 2013
    Rock Shox 32 TK Solo air, with pop loc!
    Hi, can someone please help. I have a Rock Shox 32 TK Solo air with a poploc one side and preload other side. Where is the valve to pump up the air, or how do you adjust the air. is this shock air adjustable. I'm new to MTBing. According to SRAM it should be air filled. I'm concerned as I cannot find the screuder valve to check what pressure it is.
    PLEASE PLEASE PLEASE
    Reputation: cerebroside's Avatar
    Is it definitely preload? If so you have the coil version, not the solo air.
    You can adjust your sag somewhat using the preload.
    Class Clown
    Reputation: dundundata's Avatar
    it would say AIR on the left side at the top with a cap you can unscrew.
    May 2005
    Is it an xc 32 tk? If so, its a coil sprung fork.
  1. Rock Shox Sektor TK solo air
    By jdcatnau in forum 27.5
    Last Post: 02-23-2013, 08:20 AM
  2. Rock Shox SID RCT3 Solo air compared to Revelation
    By georgelza in forum Shocks and Suspension
    Last Post: 10-16-2012, 03:32 AM
  3. Rock Shox Lyrik RC2DH Solo Air 170mm
    By Mainer in forum Shocks and Suspension
    Last Post: 09-26-2012, 01:43 PM
  4. rock shox tora 318 solo air problem
    By khcaver in forum Shocks and Suspension
    Last Post: 03-21-2012, 01:01 PM
  5. Rock Shox recon silver tk solo air
    By dww-tx in forum Shocks and Suspension
    Last Post: 06-09-2011, 06:44 PM
