    May 2013
    Require some assistance on shock options...
    Hi guys, new on the block...
    I have purchased a Neo Jumper Mtb and it has a SR Suntour Epicon LOD 6.5mm eye to eye rear shock…
    I am wanting to replace this with something better…I ride trails mainly, fast and slow, some hills with rocks and shallow ledges…
    Weigh in at 185 lbs, but carry cameras and equipment on some trips that add another 5-6 lbs...
    What is my best option being that I am limited to 6.5mm? or am I?…can I go 7.875?
    I am going to at minimum go with Cane Creek Cloud 9...
    Thanks for any suggestions…guidance...
    Quote Originally Posted by LTZ470 View Post
    Definitely use a 6.5" shock. I prefer Fox air shocks and others may suggest a Rockshox offering. I don't hear much about the Cloud 9 other than its light and easy to build - not sure if an air damper can compete w/ oil dampened shocks for performance. The I Googled the Neo Jumper and it lists a weight of 21.90 kg - hope that's a shipping weight.
    May 2013
    Quote Originally Posted by keen View Post
    Yes, it's an ebike, so a tad heavier…the 165mm is so limiting…which oil dampened shock would you recommend? Fox have something thats 165mm?Thanks...
  1. Butcher shock options ?
    By a2themfk in forum Santa Cruz
    Last Post: 01-30-2013, 12:33 PM
  2. M9 Shock Options
    By dans160 in forum Intense
    Last Post: 01-11-2012, 09:46 AM
  3. Shock options
    By karpi in forum Shocks and Suspension
    Last Post: 05-01-2011, 05:33 PM
  4. rear shock options please help
    By mxwheels.net in forum Shocks and Suspension
    Last Post: 04-26-2011, 02:47 PM
  5. AFR Shock options
    By derekr in forum Nicolai
    Last Post: 02-12-2011, 07:33 AM
