Results 1 to 12 of 12
    Nerdy Jock
    Replacing Fox Damper (Fox 32 Talas RLC)
    Does anyone know how much it costs to replace damper cartridges for Fox forks, specifically a Fox 32 Talas RLC?
    I kinda messed mine up so I'm trying to figure out the best way to fix it. I read that I could put a newer FIT cartridge into my older (2009) open bath damper fork. Supposedly that would be an upgrade.
    How much does the regular open bath cartridge cost vs the FIT cartridge? Is the upgrade to FIT worth the cost?
    Current bike: Rocky Mountain ETS-X 70
    Reputation: ShirleySerious's Avatar
    Mar 2013
    What's not working right on your existing damper?
    "This isn't the ******* comedy hour. Sober up and do it right."
    Nerdy Jock
    Re: Replacing Fox Damper (Fox 32 Talas RLC)
    My fork has been leaking oil for a very long time now. It leaks no matter what. Pools of oil have formed at the bottom of the tire underneath the fork after leaving the bike sit a couple days. It was leaving with enduro fork seals, so I replaced with skf seals a year ago, and it continues to leak.
    The top of my damper side fork is all mangled from trying to open it... it's hard for me to open it, and it's impossible to put the remains and lockout adjuster knobs on it because the mangled metal is in the way.
    I want to replace the damper to maybe fix the leaking oil issue, allow me to attach the adjustment knobs, and allow me to open the fork easier in the future. And aesthetics.
    Sent from my LG-LS970 using Tapatalk 2
    Mar 2013
    If it's leaking out of the bottom of the fork then it has nothing to do with the seal/wiper interfacing with the stanchion.
    Most likely the crush washers aren't torqued properly or have been reused enough that they are no longer sealing in the splash oil.
    I've seen replacement Fox damper cartridges on eBay cheap. That might be the most cost effective route.
    Mar 2013
    Also, I'd recommend buying or making a non-chamfered socket to prevent top cap damage in the future.
    Nerdy Jock
    Quote Originally Posted by ShirleySerious View Post
    I should have been more clear. It is leaking out of the top side of the fork. It is leaking where the fork stanchion meets the seal on the outside of the fork. It leaks whether the fork is used or not...although it isn't leaking as much anymore, I suspect the fork has emptied most of its oil by this point.
    Mar 2013
    Let me get this straight. You're saying that when the fork is just sitting there, unused, it would actively leak oil upwards and out of the wiper?
    Nerdy Jock
    Yes.
    It is as if the oil is pressurized.
    Sent from my ASUS Transformer Pad TF300T using Tapatalk HD
    Mar 2013
    I've seen the inside of an RLC damper and I can't reconcile that with what you're saying. I've got nothing for you, man. Hope someone else has an idea. Good luck.
    Nerdy Jock
    The only questions I had were how much the damper cartridges cost and if the FIT is worth it.
    Mar 2013
    Fair enough. Was just trying to save you a buck or two.
    Reputation: honkonbobo's Avatar
    Nov 2006
    call fox and they will give you pricing on upgrades/replacements like dampers, uppers, lowers etc etc.
    dont forget PUSH as an option as well.
  1. delete
    By SubaDrew in forum Shocks and Suspension
    Last Post: 04-20-2013, 05:48 PM
  2. Replies: 9
    Last Post: 12-27-2012, 07:32 PM
  3. Fox F29 120 (fit) loose after replacing seals/fluids and damper oil
    By fish0281 in forum Shocks and Suspension
    Last Post: 04-14-2012, 10:44 PM
  4. Replacing Tora TK Damper with Argyle MoCo, what oil volume?
    By elTwitcho in forum Shocks and Suspension
    Last Post: 09-21-2011, 08:09 AM
  5. RL Damper to replace my R damper on Float R 130MM
    By 434Mtbiker in forum Shocks and Suspension
    Last Post: 02-03-2011, 07:27 PM
