Results 1 to 2 of 2
    Jun 2005
    Replacement shock for 2001 Rockhopper FS Comp
    Can I take a Rockshox Psylo SL from a 2002 15-16" Rockhopper and switch w/ Rockshox Judy on 2001 17" Rockhopper w/ out problems? I've never switched a fork before. What problems can I run into? The frame switched from 2001 to 2002 also.
    I want to keep the 2001 17" and sell the 2002.
    Reputation: logbiter's Avatar
    mikeT's faq
    should have all you need.
    http://www.execulink.com/~dtierney/wmc/faq.htm
    The only problem would be if the steerer is too short for the new headtube, since you're moving to a larger frame. If there are spacers with your current stem and they make up the difference in headtube length, then you're ok.
    Quote Originally Posted by skilikehell
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. Upgrade to 1993 Rockhopper Comp FS
    By loonyOne in forum Vintage, Retro, Classic
    Last Post: 05-14-2004, 08:44 PM
  3. Mavic or Sun rims on Specialized Rockhopper Comp?
    By zugzug in forum Specialized
    Last Post: 05-02-2004, 09:23 PM
  4. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
