    reduce travel on 2013 Revelation RCT3 solo fork?
    reduce travel on 2013 Revelation RCT3 solo 140mm to 120mm fork?
    can any one clarify if this can be done.
    Shop sent me the fork, told me spacers were in the box. No spacers
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    To reduce the travel you will need to be a 120mm Solo Air Spring Kit and swap it out with the 140mm. The part number is 11.4018.010.074. I just bought the same set up.
    Class Clown
    Reputation: dundundata's Avatar
    are you sure you can't just add a spacer to the air spring? it was dead easy on my recon air except i was removing a 20mm spacer to go from 100-120
    Spacers aren't used in the new Solo Airs. Travel changes require a new air spring rod as mentioned above.
  1. Changing the travel in a 2012 RS Revelation 29er RCT3 fork
    By crazynate in forum Shocks and Suspension
    Last Post: 12-29-2012, 10:59 PM
  2. Possible/Advisable to reduce Revelation travel by 40mm?
    By miles e in forum Shocks and Suspension
    Last Post: 10-20-2012, 12:34 AM
  3. Does reducing the travel on RS Revelation also reduce A to C height?
    By Mountain Cycle Shawn in forum Shocks and Suspension
    Last Post: 10-18-2012, 03:09 PM
  4. Rock Shox SID RCT3 Solo air compared to Revelation
    By georgelza in forum Shocks and Suspension
    Last Post: 10-16-2012, 03:32 AM
  5. Replies: 3
    Last Post: 08-02-2012, 09:35 AM
