Results 1 to 3 of 3
    Reputation: vmakuc's Avatar
    Dec 2012
    Recon Solo Air - length of exposed stanchion?
    Hi,
    I have a RS Recon Solo Air on my Scott Spark 40 MY2010. By specification fork should have 120mm travel.
    But my fork had only 100mm travel with exposed stanchion length of 115mm. Therefore I removed 2 spacers and fork get full travel - 120mm. But exposed stanchion length also grown up to 135mm.
    Should the exposed stanchion length be so high? I donít think so because bike geometry is changed completely.
    By my opinion the length of exposed stanchion is now too high. On my other bike I have Tora Coil SL with 100mm travel and length of exposed stanchion 105mm.
    Any suggestions?
    Reputation: Aresab's Avatar
    In looking at the spacers you removed, how long are they? There were 2 versions of the Recon in 2010, the Race series which max at 120MM and the Trail Series which maxed at 140mm (if I recall QR versions were 130mm max). I have a 2010 Recon 351 Trail w/ 20MM axle and it is set at 140mm.
    Dec 2012
    It is a Recom SL Solo Air TK remote with 9mm QR - probably OEM for Scott.
    It should be set to 120mm travel by factory. Spacers were 10mm long.
  1. RS Recon Solo Air Rebound Hex Key Question
    By wynnbb in forum Shocks and Suspension
    Last Post: 09-27-2012, 11:40 PM
  2. '12 Marathon LR vs. '10 Recon TK Solo Air
    By wheeljack in forum Shocks and Suspension
    Last Post: 09-13-2012, 04:43 AM
  3. Recon Solo Air?
    By skankingbiker in forum Shocks and Suspension
    Last Post: 08-30-2012, 11:07 AM
  4. exposed cables vs. full length housing
    By febikes in forum General Discussion
    Last Post: 05-23-2012, 02:46 PM
  5. reba rl 29er, how much stanchion exposed?
    By Dan GSR in forum Shocks and Suspension
    Last Post: 05-15-2012, 10:22 AM
