Results 1 to 2 of 2
    Dec 2012
    Recon Silver TK Solo Air excess sag
    Hi all, my 26" recon needs its first rebuild which I want to do myself.
    For the past month I have been noticing that the sag has been increasing, but my air pressure stays constant so is not leaking (and I havent got any fatter!). In the last week or so, the dust seals have started failing as I am getting oil on the stantions and around the outside of the seals.
    I have several questions!
    Do I need to service/ dismantle the air tube seeing as it is holding pressure just fine?
    What else would cause sag to increase?
    Can I just change the dust seals and foam rings and redo new fork oil everywhere it is supposed to go?
    Last question - the Rock Shox parts guide has either a solo air service kit (part 11.4310.706.000) which has loads of o-rings, glide rings, clips, washers, but does not have dust seals and foam rings; or basic fork service kit (part 00.4315.032.20) which includes o-rings, the dust seals and foam rings but no bottom out bumpers....
    Thanks in advance for wading through my post and providing your thoughts.
    Rick
    May 2014
    My recon tk solo air make a little clunk when I lift front wheel ? Air pressure remains the same? is that normal ?
    Thanks. Shinbob
  1. Rock Shox Recon Silver TK Solo air 2013 any good?
    By trailrider24 in forum Shocks and Suspension
    Last Post: 03-13-2013, 06:31 AM
  2. Recon Silver TK 29"er Solo Air Travel Change 80 -> 100mm
    By blaklabl in forum Shocks and Suspension
    Last Post: 01-17-2013, 10:29 AM
  3. Recon Silver TK coil to a solo air setup!!??
    By longms in forum Shocks and Suspension
    Last Post: 09-10-2012, 11:20 AM
  4. Recon Silver TK Solo Air - Upgrade (Change) to Motion Control?
    Last Post: 08-20-2012, 01:13 PM
  5. Rock Shox recon silver tk solo air
    By dww-tx in forum Shocks and Suspension
    Last Post: 06-09-2011, 06:44 PM
