Results 1 to 5 of 5
    Jul 2013
    Recommendations for a 26" front fork.
    Any suggestions on a front fork for a 2004 s-works epic? I'm building up a 2004 s-works epic frame and need a recommendation for a fork. I believe it originally came with an 80mm fork, but I think I could go 100mm as well. I'm looking for a "value-build" and something I could buy used. I need a fork that works with v-brakes.
    Reputation: ColinL's Avatar
    Feb 2012
    Reputation: joe_bloe's Avatar
    Re: Recommendations for a 26" front fork.
    If I interpret your profile information correctly, you're in the Minneapolis area. CL in your area has a Rockshox SID for a good price.
    Sent from a boring meeting.
    Jul 2013
    I am in the Minneapolis area. Saw the CL post, but not sure about the 130mm shock. Thanks for the response though. I know the stock 2004 epic came with an 80mm fork, but I'm thinking of giong with the 100mm fork. Should mess with the setup too much. Thoughts? Looks like I can get the r7 pro on ebay for a little over $300 new.
    I'm not sure I believe the listing. I don't know if the SID was ever available in 130mm travel - perhaps someone else has better information than I do about that. However, it's pretty simple to adjust the travel in the SID - there are spacers available to reduce the travel. Your bike shop could do it for pretty cheap, and then you'd have a really nice fork. Any used fork should probably be opened up anyway, at least for an oil change/clean up, so it wouldn't be wasted effort.
  1. Replies: 46
    Last Post: 12-29-2013, 06:03 PM
  2. Building a "play bike" - frame recommendations?
    By burnedthetoast in forum General Discussion
    Last Post: 08-02-2013, 02:52 PM
  3. Recommendations for a 1" Steerer/Disc Brake Tab Suspension fork
    By arcdesigns in forum Vintage, Retro, Classic
    Last Post: 06-27-2013, 10:04 PM
  4. Replies: 4
    Last Post: 09-13-2012, 01:33 AM
  5. Replies: 8
    Last Post: 07-19-2011, 05:52 AM
