Results 1 to 28 of 28
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Rebuilding a Curnutt Shock
    Never done it before. Wish me luck!
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Looks a lot like a dirt motor rear shock. Are you just doing routine service or was there a problem?
    It was bottoming out prematurely. Not sure why. Possibly the ifp had moved.
    I cleaned everything up, all looked ok. Refilled with Showa fluid and back together. The bottom out appears to be acting normal now. Time for a test ride!
    Quote Originally Posted by iheartbicycles View Post
    It as bottoming out prematurely. Nit sure why. Possibly the ifp had moved.
    Just got back from a test ride around the block. Rebuild worked and bike is back to getting full travel. I could have gone a little shallower on the ifp, but going to leave it for now and see how it goes!
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    Nice! That was fast...
    Can you post up IFP depth & pressure (if you remember) for other Curnutt users that might try this?
    Out of curiosity, is that SPV?
    P
    I am in the process of rebuilding it again right now. I decided it didn't have the end stroke ramp up I wanted. Currently the ifp is at 5" measured from the center divot in the ifp to the shock housing body. I am going to try out 5.25" and see how it feels. This is for a 3" stroke Curnutt.
    I am in the process of rebuilding it again right now. I decided it didn't have the end strike ramp up I wanted. Currently the ifp is at 5" measured from the center divot in the ifp to the shock housing body. I am going to try out 5.25" and see how it feels. This is for a 3" stroke Curnutt.
    Much better! I put the ifp at 5.3" and am now able to run ifp pressure at 60psi with bottom out at 1/2 way. This enables better small bump cOmpliance and good ramp up.
    Reputation: oakhills's Avatar
    I want to see some higher res images, especially of the ifp.
    The thing in the middle is the ifp.
    Attached Thumbnails Attached Thumbnails Rebuilding a Curnutt Shock-imageuploadedbytapatalk1310486393.351771.jpg
    yep, the ifp pops out with some force when you add air to the chamber.
    I used Torco light RSF for the refill.
    Quote Originally Posted by Katana View Post
    Forgot to tell you about that. Did you get your rebuilt??
    I know this might be a PITA but how about a step by step guide with a description for each photo?? Im really keen to have service my Curnutt (done plenty of dhx coils but im a bit reluctant to rip into the Curnutt). I need some help on getting the IFP out, how much fluid and what weight to put back in and putting the if back in and what level to put it at.
    Quote Originally Posted by allmountain76 View Post
    Sorry, no step by step. To get the ifp out, just pump some air into it. Ifp depth depends on which shock you have and on personal preference. I recomend 2.5 weight oil.
    ive got the 9.5 x 3 on a 2007 fxr. Have you got guides for the ifp depth and oil levels?
    You're going to want the ifp depth around 5.3". Measured from the deepest ( center) of the ifp to the top of the shock body. I used a pencil, but any skinny tool should work.
    I think I mentioned above the shock end cap requires a 32 mil wrench. Bike shops have these, since they're used for threaded headsets.
    2.5 weight oil is kinda hard to find. I got some from a motorcycle shop. Any good suspension oil should be fine.
    This shock is not much different than your DHX. You're over qualified!
    Ive got 2.5 wt and the 32 mil headset spanner. The main difference with the dhx is obviously the piggback chamber with the ifp inside. The DHX is a PITA to be hones compared to the curnutt looking at it.
    And thanks for taking the plunge and servicing the Curnutt and then posting it!
    NP. Glad to see others doing it. Me and Katana (also in this thread) have rebuilt 2 Curnutt Coils and one Curnutt Air and each has worked out great.
    Only problem is not having info on which oil to use and what to do for IFP depth. We've had to rebuild each shock several times, figuring this stuff out. it's really simple though - and nice to be able to fine tune the ride.
    Oil volume wise, I guess no oil on the air side of the ifp. How much are you adding into the shock body side you recon?
    6 or 7 ounces, maybe? I set the IFP at 5.3" and fill the shock body about 3/4 full. Then plunge the damper and fill the rest of the way up.
    doe they normally run 2.5 weight? i'm coming in at 250lbs and want a little more small bump... would you recommend 5.3" for a fatty or run it a little shorter?
    Quote Originally Posted by shmoodiver View Post
    Updated, as I wrote up a little more detail.
    I didnt have any directions from Foes, so I had to figure out the IFP depth myself - and I took two tries to do it.
    The good news, is you shouldnt break anything if you're careful - so go for it. Here's all I did to find the starting IFP depth.
    rebuild your piston
    rebuild the shock body
    Either depress or remove the schraeder valve internals - the way the IFP can move freely in the shock body - without air pressure causing any affect.
    Insert the IFP into the shock body
    Use the piston to push the IFP all the way into the shock body. screw the cap onto the shock body - and push the IFP all the way to the point where the shock is at bottom out.
    If the bottom out bumper gets in the way, you will need to account for this later.
    Now with the schraeder valve still depressed, or removed - reverse the process, leaving the IFP at the bottom out point. Take the shock apart, again - removing all internals, except the IFP.
    Use a pencil or something else to measure the IFP depth.
    If the bottom out bumper prevented your shock from fully bottoming out - measure the width and push the IFP down further - by this amount.
    Now to make sure that during use your piston doesnt contact your IFP, you will want additional space between the IFP and the piston.
    I recomend starting at 1/2". Go ahead and push the IFP in, further by this amount.
    Re-install the schraeder valve core. you now want the ambient air pressure to hold the IFP at its current depth.
    Go ahead and refill your shock with oil - making sure to get rid of all bubbles as you go. (cycle the piston, etc)
    you should probably leave the coil spring off for now.
    Once back together and before charging the IFP, cycle the shock to make sure everything is moving nicely and you dont have interference.
    At these low pressures and forces, you shouldnt have to worry about any burps between air and oil chambers.
    To be 100% certain you have good clearance - you might want to bolt the shock onto you bike, no spring and completely cycle the shock - all the way to bottom out. Do this carefully and slowely - as you still dont have any significant pressure holding the IFP in place.
    When you're satisfied you have clearance - pressurize the IFP (minimum 50 PSI) and put everything back together.
    You'll notice in my thread that I took two tries to the the IFP depth I liked. Once you get the hang of this, you have much more flexibilty in fine tuning your shock - you can really dial in how it ramps up, which is nice.
    Disclaimer - I'm not a professional! I just have a bunch of Foes and decided to teach myself how to rebuild my shocks. This may or may not be the best way - but it works.
    Feb 2013
    I've been following this thread for a while, thanks a ton for the last update. I'm pretty sure I follow everything about setting the IFP depth 1/2" deeper than the piston could ever travel. One question, hopefully it's easy, what procedure do you use to fill the shock oil? Does the compression valving open easy enough to purge all of the air below the piston when pushing down? And what about getting all of the air out on top? I've seen some people put the entire shock under oil to get air out? Any insight? Again, thanks a ton!
    Quote Originally Posted by erniek View Post
    On the coil Curnutt this is very simple. The air bleeds out very easily and when you screw in the upper cap - it displaces some volume - and will spill out a bit. This gets rid of whatever air you might have on that side of the cartridge.
    The air curnutt is much more difficult as you have to do the above and screw the airsleeve on at the same time - so overspill ends up in the air sleeve. Then you have to bleed it out separately.
    Feb 2013
    Woah, thanks for the quick reply. This weekend I'll finally get to it and report back on how it went. Seems pretty straight forward - THX
    Feb 2013
    Well I got through the shock last night. I have a few observations that differed from your settings and maybe a reason why. First, I tried the IFP depth at 5.3". I have a 2009 Foes FXR so the shock is the same as yours I believe. Anyway, with 5.3" depth the IFP would bottom out on the cap before the shocks end of stroke (more on that later). Anyway, I settled on 4-5/8" IFP depth. I think the difference is down to how I filled up the shock. I filled the shock up about 3/4's up then put the piston in. I cycled the shock multiple times to get the air out. I pulled the piston out so it was just barely beneath the oil level (beginning of stroke) and filled up the remainder. Thinking about it, I bet you filled the shock with the piston all the way down. The way I did it would put more oil in the system and would make the IFP travel further down as the shock travel through it's stroke, eventually bottoming out.
    In searching through the forum, I saw a thread that you and a bloke from the UK were discussing an XCT 5 rebuild. He measures the IFP depth from the other end with the shock head screwed in and at end of stroke (BO ramp knob cap off and IFP exposed). His preferred setting is 10mm from IFP bottom out when the piston is resting on the bottom out bumper. Do you have a number that you've found that works well on that same measurement? That seems like an easy measurement and basis for adjustment. What do you think?
    Reputation: Dami's Avatar
    First of all thanks for the clear instructions, this will help me a lot in the future! My problem is that there's some oil coming out of the rebound adjuster wheel, so I guess there's a problem with some O-ring in the adjuster assembly. My question is that is it possible to get the spare O-rings from somewhere? I know there's a Curnutt XTD rebuild kit, but is it available for others than official Curnutt service guys?
  1. wtb curnutt shock
    By foesrider26 in forum Foes
    Last Post: 08-13-2007, 09:08 PM
  2. Rebuilding Curnutt shock
    By Dami in forum Foes
    Last Post: 07-21-2006, 10:56 AM
  3. Foes Curnutt ITD Shock & 5.5
    By Pedal Bike in forum Intense
    Last Post: 05-05-2006, 08:50 AM
  4. Curnutt Shock?
    By WeylessXPRider in forum Shocks and Suspension
    Last Post: 02-13-2005, 09:55 PM
