I was doing a periodic air pressure check on my 2010 Reba Team and reset the volumes to the preferred pressures which has the negative 10 psi less than the positive. When I double checked I found the both pressures kept showing the same numbers. I assume that there must be a seal that separates the two chambers that is blown thus equalizing the pressures. Does this make sense?
