Results 1 to 2 of 2
    Nov 2007
    Question for those who rebuild thier own Talas III...
    I am hoping someone can help...
    I need to replace some of the O-rings in my Talas III air spring. Specifically, the very small ones inside the adjustment rod that controls the shock height.
    I would rather not buy the whole rebuild kit from Fox.
    Fortunately, the o-ring sizes are on their parts / disassembly diagrams.
    Has anyone ever sourced the O-rings from a source other than Fox? If so, where did you go? I see a number of different o-ring materials...which is the best to use? I was thinking about using Viton type O-rings, but looking for suggestions.
    The other O-rings look fine. I can get three sets of the o-rings needed for the Talas for around $8.00.
    Thanks in advance
    For the small price penalty, it's totally worth it to simply buy the factory parts and be done with it imo. If those are bad, then the others are close too so you might as well tighten it up and make it new again :-)
  1. TALAS side rebuild
    By DGC in forum Shocks and Suspension
    Last Post: 12-22-2014, 04:12 PM
  2. Replies: 5
    Last Post: 03-14-2012, 05:12 PM
  3. Fox Talas 29 rlc rebuild questions
    By FM in forum Shocks and Suspension
    Last Post: 12-15-2011, 04:29 PM
  4. TALAS rebuild... how many times?
    By skogorbet in forum Shocks and Suspension
    Last Post: 10-13-2011, 05:31 PM
  5. Talas rebuild: Do I need to bang the sh*t out of it with a hammer?
    By GotoDengo in forum Shocks and Suspension
    Last Post: 04-01-2011, 08:52 AM
