Results 1 to 5 of 5
    Reputation: tigerteeuwen's Avatar
    Jul 2014
    A question about spring rates, high or low end on suggested weight. Rockshox xc30
    Hello,
    really quick question that might be general or specific based on how you classify it. I am upgrading the spring in my rockshox xc30 from the medium red which is good for 160-180 pound range to one that accomedates for more weight, rockshox is currently back ordered on the blue firm which is good for 180-200, but they do have the x-firm black which is good for 200-220.
    I float at around 195-200depending on how well my wife has fed me for the week and i ride with a pack quite often which probably add a bit more weight, generally speaking do you want to be on the low end of the suggested weight for the spring or the high end?
    They will not have the firm blue spring in till september, though it is only a $30 part i am looking for some opinions on this. Currently with my Red medium spring i have the preload maxed out and desire more.
    Reputation: mullen119's Avatar
    26 or 29 and how much travel?
    Jul 2014
    29" with 100mm travel.
    Jul 2014
    anyone have any insights on this?
    thanks for your time!
    Nov 2016
    Quote Originally Posted by tigerteeuwen View Post
    Did you ever get an answer or upgrade your spring? I am looking at a new bike with the XC30, and am in the exact same position as you. We weigh the same and I primarily use my bike to commute with a backpack.
  1. Help! Changing Spring on Rockshox XC30
    By ssorange in forum Shocks and Suspension
    Last Post: 05-14-2017, 12:10 PM
  2. Rockshox default coil spring for XC30
    By Bourdagespl in forum Beginner's Corner
    Last Post: 05-23-2014, 11:53 AM
  3. 2014 rockshox boxxer R2C2 set up - wrong spring rates?
    By Madpete in forum Shocks and Suspension
    Last Post: 01-26-2014, 11:53 PM
  4. Rockshox XC2 vs XC30?
    By mountainbiker118 in forum Shocks and Suspension
    Last Post: 07-27-2013, 09:42 AM
  5. A question about Fox Van R and spring rates
    By Fachiro1 in forum Ventana
    Last Post: 01-05-2013, 02:23 AM
