Results 1 to 6 of 6
    MTBR member-at-large
    Reputation: ThornPatch's Avatar
    Quality Fork for 24" Wheel
    Does anyone know where I can find a high quality, after-market front suspension fork for a 24" tire (kids bike)?
    If, not, what would be the draw backs to using a short-travel (80-90mm) 26" front fork (disc brake only), say like a Rock Shox Sid with a 24" wheel.
    FYI, the frame is a 2009 Kona Kula 2-4 (which I'm looking for too) which is a disc only frame.
    Thanks in advance!
    -Greg
    Better at pedaling than typing
    Former Bike Wrench
    Quote Originally Posted by ThornPatch
    Thanks in advance!
    -Greg
    Your best bet is a short travel 26" fork...find an older SID spaced down to 63mm of travel. The fork is light and the dual air allows it to be adjusted right for lighter riders. You'll want to run lighter oil in the damper as well. It will lift the front end up a smidge but you can always flip the stem to get the handle bars down again (like many 29ers do).
    Feb 2010
    Measure the axle crown distance on the current fork. You may find that the so-called 24" fork on there now is actually just a 26" fork. This is what I found when recently replacing a 50mm 24" Suntour SR fork with a 26" Mag21. Indeed the 50mm 24" Suntour SR fork was only about 30mm shorter axle to crown than a FoxF100RL, so the frame would have worked fine even with a 100mm 26" fork up front.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    put a 26" fork and wheel on it and start a new trend ... the 46er
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Former Bike Wrench
    Quote Originally Posted by Zoke2
    Not a new trend...a 26 year old Trend
    http://mombat.org/1984_Cannondale.htm
    Nov 2007
    Thanks for the link mtnbiker72 ... but since one would be hard pressed to find anyone riding one of those I wouldnt call it a trend ... interesting none the less
