Results 1 to 3 of 3
    Prep M grease or Motorex grease 2000 in Skareb Super?
    May I use Motorex grease 2000 instead of Prep M grease (prep M is manufactured by Motorex too) in Skareb Super 2004? I mean threads and o-rings. I have learnt that a liitle bit of grease should be used there (o-ring and threads). I guess they are pretty the same, but still afraid if motorex grease 2000 could harm seals/rubber.
    Motorex grease:
    http://www.motorex.com/index.cfm?fus...18-444-855-867
    Prep M:
    http://www.mtbr.com/reviews/Lube/product_78209.shtml
    Another questrion by the way :
    Should I remove and reinstal air piston when servicing Skareb for the first time ? (the air chamber oils seems to be pretty clear).??
    otb club member
    Reputation: Chris2fur's Avatar
    Quote Originally Posted by kamerek
    Motorex grease:
    Prep M:
    The grease should be fine for threads and O-rings. You said you checked the oil on top of the air piston. That's probably good enough.
    ok I have telephoned manitou service and they suggested prep M for fork's o-rings , piston, threads, and spring as it is a better solution for "traveling parts" . Other greases may make the forks much stiffer
Hot Deals
Contests
Latest Mountain Bike Articles
