Results 1 to 3 of 3
    Apr 2013
    Is it possible to convert a coil fork to an air fork
    While removing my spring in my xc32tk i accidentally broke a small piece that changes the preload and i was wondering if it is possible to just convert the fork to an air sprung fork by buying all of the neccasary components, instead of having to buy a new spring and pieces etc...
    Maybe. If the walls are scuffed from the coils, your air spring will leak. It would also be more expensive. You can more than likely buy a new preload adjuster from your LBS.
    Apr 2013
    That is true. The big problem realy is that the black x firm spring is to soft for me. I fear that if i do a drop higher then two feet that it would bottom out hard. I only have a couple hours of riding on the bike and the couple small ledges that i went off of around town got almost all of the 120 mm travel.
  1. Convert 9mm QR fork to 15mm Thru Axle
    By Koin in forum Shocks and Suspension
    Last Post: 05-21-2014, 07:14 PM
  2. Can you convert from a front shock to regular fork?
    By johnnybentwrench in forum Vintage, Retro, Classic
    Last Post: 12-30-2012, 01:58 PM
  3. How to convert a Rock Shox fork to rigid?
    By JungleBiker in forum Shocks and Suspension
    Last Post: 08-02-2012, 08:21 AM
  4. Replies: 8
    Last Post: 07-30-2012, 10:51 PM
  5. Bad Boy Ultra question (wish to convert to a rigid fork)
    By gggefffd@gmail.com in forum Cannondale
    Last Post: 03-09-2011, 10:01 AM
