Page 2 of 23 FirstFirst 12345612 ... LastLast
Results 101 to 200 of 2266
Thread: Pike 2014
  1. #101
    Reputation: jjkitt's Avatar
    Have a question
    Just received my 26" 160mm Pike. I was testing out the the settings; open, peddle, locked. In the locked position the fork did not lockout completely like X-Fusion or a Fox. It did compress slightly and with the feel of very heavy damping. Those that are running the Pike is this the same for you?
    Cheers,
    "I Like the Cut of His Jib"
  2. #102
    Pike 2014
    Yeah. I'm pretty sure they said that's how it's supposed to work. If you want go check the pinkbike coverage of it. Basically it doesn't lock out it just gets really firm.
  3. #103
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by jjkitt View Post
    Cheers,
    On the bike the compression adjuster has a pretty big effect, it doesn't turn it into a rigid fork, but it gives enough compression damping to make it resist bobbing if you are pedaling up a hill or something. Where it really shines is in rough chunky terrain where you don't want it blowing through travel. A few clicks of the adjuster keep it from diving and it still feels great, not harsh. It's exactly what low speed compression is supposed to be IMO.
  4. #104
    So, found the fork entirely too linear out of the box on my initial test ride. It felt really unstable, but there was pretty much no compression damping. The fork is a 150mm 29er non-adjust travel fork.
    Initial ride setup was 60 psi to 25% sag. Rebound was 9 clicks in from full open, or roughly 50% LSR damping.
    I opened up the air chamber and noticed the fork already has one of those bottomless tokens in. I stuck in the other two for a total of 3...
    Now the fork is at 40 psi, 27.5% sag, and it ramps up quite nicely! Prob will need to dial out 2 or 3 clicks on the rebound for the reduced PSI and to get the small chatter compliance I'm looking for. Test ride to come, once the rain stops.
    I like to set the compression damping to non-existent for climbs so the front wheel can follow the ground w/o any of my weight on the bar. On the downs, turn to the middle of the RCT3 setting to get some mid-stroke support. This was how I rode the Fox 34 to pretty good effect.
  5. #105
    Yebo Numzaan
    Reputation: Muttonchops's Avatar
    Well...is this where everyone gets confused? I have come to understand that fork manufacturers refer to low speed compression as being the first 1/3 of the forks travel. This will be forces that do not force the fork to travel more than 1/3 of the way thru its travel. Exactly...pedal induced bobbing etc...these get reduced by the compression settings and possibly eliminated if LSC is maximised or the fork is locked out.
    when we start talking about rough chunky (high speed?) terrain i want my fork open so that its active as possible and if there is a risk of it blowing through its travel - then i should be playing with the high speed compression...which is the final 1/3 of its travel. If I enter the final 1/3 of my forks travel I want to be able to determine how i am going to use that travel...because that affects my immediate future (health).
    When i am riding high speed rough chunky terrain...i picture myself riding in the middle third of the stroke and pushing into my HSC settings. In my perect world..LSC would be irrelevant once i get going on a DH.
    cheers.
    I support EMBA
  6. #106
    Pike 2014
    Yeah that's not how it's supposed to work. Low speed compression is dampening for low speed events like going off a drop or braking or riding a berm. High speed is stuff like going up a drop (imagine going up a curb at 20mph). If you are riding down hills only using the middle part of your travel your fork is packing down and you have too much rebound dampening.
    Most forks don't have high speed compression adjustment. Downhill forks and forks like the fox 36 do but the pike doesn't, at least not via a knob.
  7. #107
    Reputation: kragu's Avatar
    Pike 2014
    Quote Originally Posted by BushPilot View Post
    Got a 160mm on the way for my SJ EVO 26.
    Bikepartsexpress / Sage Cycles have them for under $900.
    $804 at Tryon Bike.
  8. #108
    Pike 2014
    Quote Originally Posted by Pau11y View Post
    Honestly I'm glad they made it pretty linear and then provided the bottomless tokens to allow us to tune it. It just gives us more options. I have about 20 hours on the fork right now and am still playing around with it. I've already shaved around 30 seconds off one of the 5 minute trails I ride with this fork. Crazy as that sounds. I'm thinking about putting another token in when I do the 50 hour service. Good to know it already has one in there.
  9. #109
    That's what I'm doing too, working great.
  10. #110
    Quote Originally Posted by Muttonchops View Post
    cheers.
    No, low speed events are once which compress the shaft at a low-speed. A drop is a relatively low-speed event, because you only drop at 9.8m/s^2, yet hitting 4" bump at 30mph requires the fork to move MUCH faster than that low-speed event. You can't have the same damping circuit doing both events though, because damping increases as a square of velocity, which means the fork would simply hydro-lock and not compress when you hit that 4" bump if all you had was the low-speed compression circuit. High speed damping has to open up, and the faster the fork moves, the more it has to open. So going back to low speed, it might seem that it exists mostly in the beginning stroke, but that's not really true as you experience g-outs, do drops and jumps, and so on. No matter where the fork is in it's travel, it has to be able to do both of these things, such as landing a drop AND absorbing a root during the landing.
    What noticed on my avalanche stuff with fairly high-end low speed and high speed circuits was that you needed a certain amount of low-speed compression dialed into the fork/shock for the high speed circuit to work correctly. If you tried to leave it "open", it worked well enough at low speed, but at higher speeds it wasn't allowing that high-speed circuit to open up enough, so it was kind of sending oil to both circuits and not effectively decreasing the high speed damping. Upping the low speed compression damping helped it resist g-outs, diving, pedal better, and most importantly to me it seemed to help the high speed circuit open up much better when the fork reacted to a high-speed event. Sometimes this stuff seemed "overdamped" compared to an old marzocchi fork, but you take the avalanche stuff through crazy south-mountain or goat-camp super-chunk and it just leveled stuff, the faster you went, the better it got. That's what I notice from the pike.
    Compared to some of the marzocchi stuff I've had over the years, the older HSCV stuff was kind of "tuned" for moderate speed riding with little chassi control, at low speed it wallowed and moved around a bunch, at moderate speeds it wasn't bad, but try to push it to high speeds and it just gets overwhelmed, spiking, etc. Those dampers were crude and any increased compression (closing off holes) made them feel pretty bad. The RC3 I got much later was also terrible, it had a spring on top of a check-valve, kind of a poor-mans shim-stack type damper, in some ways worse than the older HSCV which at least had crude shims on it. Increasing the compression damping here just made it feel worse...at everything. Newer marzocchi RC3 Evo 2c Type R or whatever they are calling it is actually decent and nearly a carbon copy of some of the avalanche stuff.
    It's really not possible to have true adjustable high speed compression, you have to re-arrange the shim-stack. You could theoretically have a system that pre-loads the shim-stack and adjust the preload on it, but that's not the same thing as having different size or more/less shims on there either, not to mention the low speed compression blow-offs and associated springs, piston size, etc. This is usually tuned fairly well from the factory though if it's a decent damper. If it's a proper compression damper, you can increase the low speed compression without ruining the high speed ride, which seems to be what we have here with the pike. It's not like some of the products where putting in compression damping affected both the high and low speed circuits and caused the fork to spike like crazy as you tried to slow it down a bit. That's unfortunately been the "standard" for most mountain bike stuff for a long time, but really it's simply ill-performing dampers from companies too lazy to adapt proven and available technology.
    I'm no suspension expert, but going with what I know about damping so far, you'd want even less high-speed compression damping and more low-speed the faster you go in chunkier terrain. Not doing this will result in spiking due to the high speed impacts being too fast for the high-speed damper (not able to open enough for the faster impacts), and the fork will bottom due to the bigger low-speed impacts (rolling off rocks, possibly combined with high speed impacts, landing jumps, etc).
  11. #111
    cheers.
    I'm getting the feeling you're confusing position sensitivity to shaft speed sensitivity.
    Think about this: 30mph and hitting washboard...I don't care how smooth those rolls are, the damper shaft speeds will be moving fast. You'll only use 1/3 to 1/2 of your full travel (if your HSC and HSR are set correctly). Now, same 30 mph and you take your bike into a 40ft diameter berm...that damper shaft speed will be moving pretty slow as compared to the washboard. BUT, if your LSC and LSR is set correctly, it's likely you'll be in the last 1/2 or 1/3 of your travel as you pull maybe...1.5 or 2 G's in that turn...?
    So, to dissect Jayem's response a bit...
    On a drop...say 4ft...and ONLY w/ respect to compression, that would be a fast moving damper shaft speed => HSC.
    On the in-run of a ramp (or you can also think of G-outs here) and only w/ respect to compression, that shaft will be moving pretty slow in comparison to the impulse from landing a drop => LSC.
    Now, w/ respect to rebound ONLY on the same two events above...
    Chances are, when you roll off the drop, you're rolling off the edge of a flat area, so your fork will only extend from its sag point to full extension. The stored energy from only compressing the spring somewhere between 25 and 35% is relatively low, resulting in low shaft speed...=> LSR.
    But, when you load up a bike off the lip of an air, chances are, you're WAY deep in the spring's stroke. The release energy from that spring will be pretty high, making the shaft movement fast...=> HSR.
    Edit: actually, what you described sounds more like a description of rebound...
  12. #112
    Te mortuo heres tibi sim?
    Those of you who've played around with the bottomless tokens: think they'd work in some of the older Solo Air forks? I've got a Totem Solo Air on my big bike that even with lots of tweaking, I still have a hard time getting it to feel great on small and slow stuff while ALSO feeling great on big and fast stuff. Thinking those, or something like them, would do the trick. Like shimming the air can on HV can rear shocks, yeah? It's my only real complaint with the fork. The bike sees a mix of local trail riding, as well as resort time. The local trails have lots of slow speed trialsy and techy things interspersed with faster bigger hits.
    Let me run lower pressure to get a bit more small bump compliance, yet still be able to handle larger hits, while using the compression circuits to keep it from being divy and wallowy?
    Pike content: Ordered up a 26" non-adjust 150mm model... It's going to replace the lowered Lyrik Solo Air on my TRc. Lyrik will go back ont he TransAM it came from, and the aging Revelation Dual Air gets sold to help pay for things!
  13. #113
    Quote Originally Posted by scrublover View Post
    I haven't tried the tokens yet, but I did let a lot of air out of the fork and tried to ride it like that last night. Didn't work great, it was better with more air in it, more sensitive to bumps and such, if that makes sense. I don't think it was absorbing the roots and square impacts quite as well with the pressure let out, I was getting more front end movement too, but I didn't try to adjust the damping settings at all. Usually the problem with air shocks seems to be getting all the travel, I was getting a little too close to bottom on a few jumps last night with more sag. I guess tokens would be good to try, but the fork still felt damn good with the slightly higher pressure I was running (about 70).
  14. #114
    There's a trick used on the Fox Float forks...just shoot suspension fluid into your air chamber to take up volume. Once you figure out how much, you can replace it w/ something solid. As for Totems and tokens, does your Totem have a threaded piece under your air cap where you can thread on those tokens? If not, you might want to figure out a way to secure them onto the top of your air piston...
  15. #115
    Quote Originally Posted by BorisD View Post
    Hoping fellow Pike owners can confirm a suspected problem.
    Got my new Pikes yesterday 26" 150mm, was very pleased - weigh only 80g more than my RCT3 Revs (1801g vs 1727g both with a 195mm steerer). Amazing.
    Very stiff and not as 'divey' as the Revs they replaced.
    However I think the damper is not working as it should -
    The dial adjuster only has two 'clicks' - one for fully open; the other when selecting platform; but no 'click' when selecting lockout.
    In lockout I can easily get 55mm of travel by pushing down on the fork.
    The Low Speed Compression has very little effect.
    When the rebound is on full 'slow' the fork still returns relatively quickly.
    Can someone confirm their fork does not behave like this?
    This is how my fork is as well. No click on the lockout setting.
  16. #116
    Not that I recall, but if there is, I doubt it would be the same size as what is under the Pike cap anyhow. Will take a look, and play with some oil in there to see how it feels.
    Figuring a way to stick something on the underside of the cap doesn't seem as if it would be too hard to figure out.
  17. #117
    Pike Dual Position Users
    Has anybody with a Dual Position Air (DPA) Pike ridden it much in the low travel position?
    This thread says that the DPA low position (on a Revelation) is intended mainly for climbing and the air spring in that position is too linear to use all the time. Can Bottomless Tokens be installed on the DPA model or are they only included with the Solo Air model? Is it possible to set up the DPA Pike to have good performance in the low position without ruining the performance in full travel mode?
    I'm contemplating buying a 29" Pike with DPA and would prefer to use it in 120mm travel mode most of the time, switching to 150mm mode only for the most rugged trail sections.
  18. #118
    Reputation: brentos's Avatar
    A few notes on my Pike. 140mm 29er, 46 offset.
    -I couldn't get full travel out if it at first, even with pressure lowered 15 psi under recommended. It felt awesome, but I just could only get 110mm of travel. Found that there were two volume reducing tokens in it from the factory (as well as two in the box). Removed them and it felt much better, ended up putting one back in to better balance it to the rear suspension on my Scott Genius.
    -No sag gradients on the stanchions.
    -Smoothest fork I've ever felt.
    -It's lighter than claimed 1863 g no axle, 1937 g with axle. And that's with two air reducers in the air chamber. (16 grams each)
  19. #119
    Quote Originally Posted by brentos View Post
    This is good info thanks. I'm experiencing something similar on my rig, new Knolly Endorphin with 150mm 26" Pike. I've slowly kept lowering the pressure but still haven't bottomed it yet. Right now I'm about at 65 psi, and I'm about 215 RTR. At this pressure it's a bit more divey than I like, even with the LSC almost all the way cranked in open mode. I'll pull it apart this weekend and check to see if I have some of those tokens installed, my guess from reading your post is there might be.
  20. #120
    Reputation: bubba13's Avatar
    Could someone please post A-C numbers for all of the variations on this fork?
    I found the attached thumbnail from another thread but it will not open. Online search only gets a blurry chart that cannot be read.
    Considering this fork for my Knolly Endorphin, but cannot decide if I will go with the 26" 150/160mm or 27.5 150mm version. Currently running a Fox 36 Float set to 150mm for 535mm A-C and external cup HS.
    Portland Off Road Navagators
  21. #121
    Bubba, I can't remember but I looked it up long ago before I ordered mine. IIRC, the 26" 150 (which I bought) has a 532mm AtC, versus a 150mm Revelation at 528mm.
    Not sure about the others since I wasn't interested in them.
  22. #122
    Pike 2014
    My 29" 150mm is 558.
  23. #123
    Quote Originally Posted by hillharman View Post
    PM sent.
    Cheers.
  24. #124
    Reputation: wreckingrob's Avatar
    I tried everything i know - all ranges of air pressure (high / med / low) , changing damper fluid and playing with my compression settings as described. I ordered the Pike....kinda answers the question as to whether i was succesful.
    re: the Revelation...single big hits were actually fine. It soaked up a surprise 3' nose heavy roll over this weekend when for sure i thought i was going OTB...but when it came to high speed chunder / roots and heavy front braking - it struggled.
    Everyone sounds stoked on the Pike...and I am enjoying reading all the feedack / input. Hopefully I will be able to "plug and play" when it arrives.
    thanks.
    @MuttonChops: I had the EXACT same problem with my Revelation. It is a great fork for regular trail riding, but give it some chop and it seemed to stiffen up horribly. Replaced it with a Pike on my SB-66 and its a new bike. The Pike really softens up the choppy roots and rocks, and takes a big hit nicely.
    If your not wreckin', your not ridin'.
  25. #125
    Quote Originally Posted by rscecil007 View Post
    Thanks! It looks like the 27.5" 150mm lands at 542mm a-c. Same as the 26" 160mm.
  26. #126
    Just a PSA/heads up.
    I've been dinking w/ the bottomless tokens... I said before I stuck in 3 of them into the 150mm 29er fork. I can say for certain that the fork won't bottom onto those three (3) tokens.
    Let out all air and pushed until the crown bottomed on the main seal...all good. AND, the progressiveness w/ 3 tokens felt great...w/ just a hair over 50psi pressure, and LSC wide open.
  27. #127
    It's here, and it's sweet already!
    Dumped rain most of the day, so no trail time. Should be able to get a ride in tomorrow.
    Out of the box, playing around with pressure and damping, smoooooooooth! Ended up popping two tokens in, and dropping pressure a touch - feels good - around the block.
    I usually ride with a shock pump anyhow (all my forks/rear shocks are air) but will take the socket wrench along with so playing with the spacers on trail/mid ride will be possible.
  28. #128
    Looks good!
    You bring up a question with the tokens. Mine feels a bit better with less pressure, but a bit too divey (when full open) and I'd about guarantee I'd bottom it often. A bit more psi corrects those issues, but then it's not as plush. So I was wondering if I ran the lower pressure but with a token or two, if that would help the dive situation? It seems like it might in theory, but I can't say for certain.
    Right now in open I've got the LSC about 3 clicks from full hard IIRC.
  29. #129
    Looks good!
    That's exactly how you want to use them.
  30. #130
    Reputation: rehammer81's Avatar
    Jun 2010
    Re: Pike 2014
    So I have a new Pike waiting to go on my new Firebird build. If you guys don't mind, what are your riding weights and when you added tokens was there already one installed like I have seen mentioned? I'm 155lbs. Then add some weight for gear and some amount of hydration. The lighter the rider the less you would need the fork to ramp up by using the tokens in theory right?
    Specialized Epic 29
    Intense Tracer 29
  31. #131
    Reputation: Nickbm3's Avatar
    Yeah thats my understanding, lighter rider needs less progressiveness so less token spacers. Im about 245 ready to ride, and could pretty easily bottom my pike with ~80 psi in it (with an accurate shock pump, the pump that came with my fork is about 30psi low), and that was at 15% sag. My pike did have one token installed from the factory, and I just added another. Going to try it soon at just above 20% sag with 2 spacers and see how it feels.
    "That's a niiiiiiiice biiike boy! That a Huffy!?"
  32. #132
    Feb 2012
    Anyone have trouble with their forks?
    When i originally set my sag at 25% it required about 70psi. Now it is sitting at 30% sag with the same pressure. With 0 psi it rests at about 50% sag and i cant get it to fully extend unless i pump it up to 150psi. even with no weight on the fork (in stand) it sits at 50% sag at 0 psi.
    Is there any negative spring i need to know about???
    Also the rock shox site says to use 0w30 oil in the lower legs. Not to sure about using multi grade engine oil.
  33. #133
    Quote Originally Posted by 11highlights View Post
    Q: Anyone have trouble with their forks?
    A: Not yet...but mine are low miles, yet
    Q: Is there any negative spring i need to know about???
    A: Doesn't the SoloAir spring have communication between the positive and negative spring chambers? On the Monarch rear shock there is a little pressure equalization dimple on the air can, reached when the shock is at full extension... I'd wager there's something like that for the fork also. I'd try pulling on the bar w/ foot on the axle to see if it releases the negative air...
    Q: Also the rock shox site says to use 0w30 oil in the lower legs. Not to sure about using multi grade engine oil.
    A: I used synthetic 20/50 engine oil in Fox forks for lube oil...works beautifully; no issues at all! And, Fox didn't say a thing when my 34 went back to them 4 times...no seals swelling, nada.
    Answered in-line...
  34. #134
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    How are you guys conducting the sag measurement? IE, how do you weight the bike to get a proper sag reading?
  35. #135
    Reputation: ColinL's Avatar
    Feb 2012
    Quote Originally Posted by Simplemind View Post
    Put on all your gear. Hydration pack if you wear one, with water, full bottles on the bike of not. Helmet, shoes, the works.
    Put your bike near a wall or in a hallway. Get on the bike in whatever position you will use most, either attack or seated. Lean lightly against the wall, and attempt to balance. If the travel indicator o-ring / zip tie has a gap to the fork or shock, move them in place. (This would mean you bounced the bike when you got on it, but it's not a big deal.)
    Get off carefully and measure or read the sag.
  36. #136
    Fully kitted up, seat position instead of attack, w/ Reverb at full ext....basically, climbing position. Done on flat ground as a trade-off between pitched up and lifting (climbing) and pitched down and brake diving (downhilling). LSC on front and rear wide open. Bounce on the bike to get it to settle in, then move the o-rings down.
    For me, I like both ends at ~27% sag, but that's just me.
  37. #137
    Dab-O-Matic
    Quote Originally Posted by ColinL View Post
    OK, just like you do with the rear. Always seems like the rear takes more "static weight" than the front, especially seated, so I was wondering if there was a different treatment for the front.
  38. #138
    Mar 2011
    Because of this I have never liked to measure sag on my fork. I feel like if I get the sag right in my garage it is way too soft on the trail. I've resorted to trial an error with a shock pump in my pack on the trail. Once I get it feeling good I remember the psi.
  39. #139
    anyone have a review of the dual position version to share?
    anyone have a weight for the 650b dual position?
  40. #140
    anyone have any tire clearance issues? Im wondering if a 26x2.4 trail king will fit in the 160mm 26" pike
  41. #141
    2.4 trail king fits with plenty of clearance
  42. #142
    endorphin addict
    Plenty of clearance for even a large volume 2.5
  43. #143
    Quote Originally Posted by strader View Post
    thanks guys. I have the pike with 2.25 ardents now just wasnt sure how much bigger the 2.4 trail kings would be compared to them. Going to be mounting them on flowex wheels. going to order them up now.
    strader have any pictures by any chance?
  44. #144
    Feb 2013
    Re: Pike 2014
    I wonder when this baby will ever reach the Far East. Seems North America and EU get theirs first.
    Posted via Tapatalk
  45. #145
    Pike 2014
    Quote Originally Posted by nyrangerfan222 View Post
    Not going to be a problem. Tons of clearance around a 2.35 Hans Dampf.
  46. #146
    Pike 2014
    I've been tinkering with my Monarch to try to get it to match the feel of the Pike and I can't get it even close. Is it just me or is this driving anyone else a little crazy?
  47. #147
    live long and huck
    Reputation: Optimus's Avatar
    Quote Originally Posted by scvkurt03 View Post
    Pike feels similar to a CCDBair. My bike now rides like a magic carpet.
  48. #148
    Pike 2014
    Quote Originally Posted by Optimus View Post
    I was afraid someone would suggest a piggyback shock. I'm riding a RIP 9. No room (or real need) for a piggyback.
  49. #149
    live long and huck
    Need?? Who cares about need? It's want. I want, I want, I want!!!
  50. #150
    Pike 2014
    If there was room, I'd have ordered one 5 minutes ago.
  51. #151
    Mar 2011
    How is the small bump compliance? Im tossing up a Pike or a 55 RC3 Evo.
  52. #152
    It's the real deal.
  53. #153
    on my 3rd wind...
    Reputation: SingleTrackHound's Avatar
    Jul 2003
    Have both and just replaced 55 RC3 with Pike solo 160mm yesterday and went for 22 mile ride that has 4kft climb and 9 mile descend. Not as good as 55 RC3 on suppleness and tracking but good enough. I am running 55psi which is 10psi below my recommended rider weight. It yields 20-25% sag. I am going to run 50psi on next outing. From what I understand factory preinstalls one bottomless token but I havent opened it up to confirm this. Definitely rides higher up in its travel than other forks. Biggest gain I am seeing is 1.2lbs in weight saving and front-end feels so much more nimble. Feels plenty stiff but not as stiff as 55.
    FYI, I am running 650B version 160mm Pike on 26" bike since I was looking to raise the front-end height a bit.
    sth
  54. #154
    Jun 2005
    Good job! My 2 cents
    Got a three hour ride on my brothers 140mm pike. Really quick background is that I love coil forks....my favorite is a 160 mm lyrik and I've got a 150 coil revelation, converted. Hate air fork for the stiction and lack of mid support.
    My ultimate fork would be the new pike with a coil uturn.
    My ride on the pike was so impressive I had to post a review....although I don't want to pay msrp I would love to find one cheaper. I found the small bump unbelievable for an air fork and rockshox was right that this indeed does ride higher in the travel. Big hits where plush of course but my biggest need in a fork is small bump and this was awesome. And of course it was almost 1.5lbs lighter than a coil lyrik. Stiffness was great and all the compression damping worked excellently. Another impressive feature was on e dh the fork maintained its plush small bump as sometime my other forks would stiffen up (damper oil foaming maybe?). But really great on extended dh. Will prob hold onto my lyrik until I find a pike cheaper but I'm excited about the thought of getting one.
    Oh, my biggest complaint was on an extended steep dh, the fork rode noticeably more into the travel....brake dive. I'm sure there was a way to combat that, more psi or spacer but it wasn't a big deal as the majority of the ride was awesome. So overall it rides really really close to a coil and possibly would replace my coil lyrik.
  55. #155
    Pike 2014
    Check Tryon Bike for good prices.
  56. #156
    on my 3rd wind...
    Jul 2003
    ...or at Art's Cyclery and use promo code "facebook20" for 20% off
    sth
  57. #157
    Jun 2005
    Thanks for the links....I guess every retailers best price is 20% off retail. Same for both and pretty consistent on ebay as well.
  58. #158
    on my 3rd wind...
    Jul 2003
    I dont see better deal coming anytime soon unless RC model shows up for less $$$ or people starts reporting massive reliability issue. Performance wise nothing beats this fork at its weight and travel spec.
    sth
  59. #159
    Pike 2014
    I have been riding this fork for over a month now and I am extremely satisfied. It's very impressive how consistent the fork is. Riding through a long rock garden there is no noticeable difference towards the end. The fork recovers very well from each hit and stays controlled the entire time.
    One big advantage of this fork is the small bump compliance. Compared to the fox 32s I've ridden (talas and float) which are the same weight as this fork, the difference is night and day. Not only out of the box is the small bump compliance better but after a lot of riding its still way better. For example I demoed a brand new bike with a brand new fox float on it and in a weekend of riding the small bump compliance got much worse. This is par for the course in my experience with multiple fox 32s. The fact that this pike keeps impressing me day after day with the small bump performance is just amazing. This is why I really, really like the fork. The performance doesn't degrade.
    When I first got the fork it was a very difficult decision. It's very expensive and I couldn't demo it. I thought I was making a huge gamble. Looking back I'm so happy I pulled the trigger.
  60. #160
    Reputation: jon123's Avatar
    Quote Originally Posted by SingleTrackHound View Post
    Thank you!
  61. #161
    How is the new Pike 160mm compared to Lyrik RC2DH?
    I am choosing between the two forks, I mostly do trail riding but occasionally I'll take my bike to bike parks using DH tires and like to ride in rough terrain. Next bike will probably be a Covert 26" with 160mm.
    I don't need lock out but being able to lowering a couple of cm is a plus.
    Pike is lightweight but I really dont like 15mm axle...
    All these decisions make my life so hard to live
  62. #162
    Reputation: intensworks's Avatar
    DUAL POSITION Up to 30mm? up to 20mm? up to 10mm?
    My apologies if this has been brought up in this thread but can a fellow member confirm if the new dual position Pike forks can be set to have dual position at 160 /150 mm. I see some ads with the Pike sold at 160/140 mm so this tells me the 30mm is not the ONLY setting in between. Am I smoking something strong today or is my question legit? Is it a matter or tinkering with internal spacers? Thanks to all.
  63. #163
    So anyone done and oil change yet?
    What the hell does bleed mean for the Pike damper?
    0w30 for the lowers is nice - cheap and easy to get at most any auto parts or moto store. Actually, same with the 3w for the damper side upper.
    This is the first RS fork in along time that I've not broken down and done an oil change to right out of the box. Doesn't feel as if it needs it yet by any stretch, but, curiosity is getting the better of me...
    Nice to see some documentation starting to show up finally.
    http://cdn.sram.com/cdn/farfuture/wX...oairtokens.pdf
    Appears as if you can run up to 4 tokens in the 26" 150mm (what i have) though mine only came with two in the box. Likely be a while before they'll be available to buy aftermarket.
    Wonder when the next spare parts lists and full service docs for this thing will be available.
  64. #164
    MTBR Member
    Reputation: ncfisherman's Avatar
    The closed damper only holds a set amount of oil, so they don't list the specific amount(?). Just fill it up and bleed the air out.
  65. #165
    Quote Originally Posted by ncfisherman View Post
    Gotcha - that makes sense.
  66. #166
    Lightly salted
    Reputation: fuenstock's Avatar
    What the hell does mean for the Pike damper?
    You most likely have a token in the fork already, Both my 140 29" and 160 26" pikes had 1 token pre installed and 2 in the box for a total of 3 tokens each.
    Heres a video of the Pike bleed,,
    <iframe width="560" height="315" src="//www.youtube.com/embed/Nninf6lN0SA" frameborder="0" allowfullscreen></iframe>
  67. #167
    Quote Originally Posted by fuenstock View Post
    Nope. Already installed the two tokens mine came with - none were in the fork when I opened it up. Their pdf doc shows (in my model at least) you can have up to four.
    Thanks for the link!
  68. #168
    endorphin addict
    How does the ride compare with the Tokens added? Did you put them in so you could run more sag and not bottom out?
  69. #169
    Yep. The fork wasn't feeling wallowy or too divy, but would use up a lot of travel and/or bottom on small stuff, even with compression cranked up.
    The tokens lets me run less pressure and LSC while still not feeling wallowy or divy, and not using up lots of travel or bottoming out little shit.
    On the biggest/harshest landing drop (at least that i do on my trail bike) on my local stuff, I'm using all but a couple mm of travel according to the o-ring. Still is soaking up the little trail chatter as well. And I'm riding all the time with the damper in the "open" position - I'm a set it and forget it guy, so once I get it all dialed in for me, I tend to not screw with things.
    We have a fun mix of high speed short and steep ups and downs, interspersed with slow speed technical, and lots of slow speed trialsy stuff alternate lines here and there - so far, the fork has been feeling freakn' awesome on all of it after popping the tokens in.
    I'd actually like to get myself two more tokens to play with, just to see. As well, if the Pike inner threaded top-cap would fit the Lyrik, I could play with the spacers on that as well - that fork is now on an older/backup/loaner bike.
    Anyhow, I suspect the charger damper and volume spacer top-caps will make their way onto all their new forks. Would be sweet if they'd offer a way to retro-fit the stuff to some older forks. Would be sweet in the Totem Solo Air on my big play bike that sees local trail riding AND lift served time.
  70. #170
    Update!
    Pike air cap will fit a Lyrik. I put mine in with the two tokens installed - no problem. Measuring the internal height, it appears there is physically space to fit four of the things without mechanical bottom out/issues. Once they have the spare parts out there, that will allow a lot of tweaking of older Lyriks for not much cash! Nice!
    The only real difference of the top-caps, other than the internal threading, is the Lyrik one you can remove/swap the entire schreader setup vs. only being able to swap out the valve core on the Pike cap.
  71. #171
    Update!
    How heavy are you and what air pressure are you running? Just trying to calibrate myself.
  72. #172
    2014 pike dual position 29er fork available in black or only in white?
    2016 YT Jeffsy 29 Cf Comp 2
    2015 YT Capra Pro Race LE
    2013 Specialized Stumpjumper FSR Comp 29er
  73. #173
    Pike 2014
    There seems to be a black 160/125 available on the new WFO. Is that available aftermarket?
  74. #174
    Adding tokens, and lowering the pressure would help the fork ride lower, use more travel on hits, possibly not have enough for the next successive hit in very chunky terrain. It sounds based on your description that you want it to be less progressive and more linear, which means less tokens and higher pressure, vs. more sag and lower pressure.
    But it's great that it's tunable and just performs amazing. I keep thinking: "A 4lb fork?".
    All I really want suspension-wise is for this kind of good damping technology that you have in the more "downhill" oriented stuff to be applied to the more XC stuff, rather than the simple and sometimes poorly-working XC systems that have all the fads like levers and and lockouts. Just give me decent damping and tunability and screw the rest.
  75. #175
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Black 36mm 27.5" Lyrik.. wonder what that would cost
    All barks have been rendered into english...
  76. #176
    Hey guys!
    Anyone knows if reducing a 160mm pike 29 to 150mm is possible (2014 model)?
    If it is possible, do I have to change damper or maybe just deal with the spacers?
    Thx, Mo.
  77. #177
    Has anyone had issues with the fork making a rattling feel when holding the front brake and rocking it for and aft? It is were the upper stanchions go into the lower legs I think. It is a 160 26" dual position air. PLEASE HELP
  78. #178
    Reputation: expatrider's Avatar
    Feb 2005
    Quote Originally Posted by ski1970 View Post
    Sounds like your headset is loose and needs adjusting. Check that.
  79. #179
    No that was checked and also taken apart and re grease and set back up. It is tight and good
  80. #180
    Dec 2010
    Hi there,
    I am riding Pike2014 on my v1 Banshee Spitfire for a month and very satisfied, but I am planning to move forward to new Spitfire and run 27.5" wheels, so my question is, is it possible to convert 26" Fork to 27.5" ? may be by replacing bottom "legs" ???
    Thanks in advice
  81. #181
    on my 3rd wind...
    Jul 2003
    I have the 650B version 160mm Pike. I am pretty sure lower is the only part different among 26, 27.5, and 29. I believe lower is taller by 10mm on 650B version vs. 26" on same travel version. I am currently running 650B version Pike on my 26" frame with 26" wheelset. I see a bit more gap between the top of tire and the bottom of lower arch than other 26" fork setup I have.
    sth
  82. #182
    Which brakes, some flavor of the new shitmano? My M820 pads rattles in its caliper. Grab a handful of front brake and move the bike back/forth, and I can feel the rotor shift in the caliper when you pinch the rotor w/ your finger right next to the caliper.
  83. #183
    Pike 2014
    Am I the only one who is losing travel when setting the proper sag? At 25ish% sag my 160mm 26" Pike is sucked down to the 5% used mark with no pressure on the front of the bike.
    Any way to solve this other than putting more pressure in then I want to?
    I am 205 lbs, so not a lightweight... If it is happening to me than lighter riders must have the same issue...
  84. #184
    Not the brake
    It is not the brake. I Have located a slight movement sound were the stanchion goes into the lower leg and can feel a slight movement as well.
  85. #185
    Dec 2010
    Thanks, I also think so, but I want to be sure, is any ability to contact sram?
  86. #186
    Delirious Tuck
    Reputation: thefriar's Avatar
    Okay... so where do I get the tokens? I'm already at 2 in a 150mm 26 and I think one more and I'll have the small bump and High Speed progressiveness I'm keen to have.
  87. #187
    Quote Originally Posted by thefriar View Post
    How much do you weigh? And on what frame if you don't mind sharing...
  88. #188
    Reputation: jazzanova's Avatar
    Re: Pike 2014
    Has anybody put a 29" 140mm internals to a 650b pike?
    I have seen 650b 140mm pike and it required changing the internals. I am just trying to find out how it was done...
  89. #189
    Delirious Tuck
    255 geared. 2013 XL Knolly Endorphin.
    I'm close. I think one more token gets me the balance and performance I want, as it sits with 2 tokens, it is already better than the 13 Fox CTD its replacing (although Fox is sending me 2014 cart so that may go back on as comparison and possibly get the Fox Enduro/MX 34 tune).
  90. #190
    Pike 2014
    Quote Originally Posted by kroe View Post
    Most forks will do this. It's not a big deal and its one of the reasons it feels so good on the top of the stroke. What kind of pressure are you running? I am 195 plus gear and run 70psi and 4 clicks from closed on the lsc.
  91. #191
    Cool, thanks. I'm 215 on a L Endo myself. I've not tried messing with the tokens yet, but I did check and mine didn't come with any installed.
  92. #192
    Delirious Tuck
    I'm going to call RS today and see where I can get more tokens.
    Didn't notice one. Two started to make things a bit more noticeably progressive. I think three will give me the small bump, sag, and the ramp for more aggressive lines/chunk.
  93. #193
    endorphin addict
    Let us know. I'd like to get another one too.
  94. #194
    Delirious Tuck
    Pike 2014
    On the way to my local shop. Have your LBS call and request SRAM to send the tokens. Should be a few days. Going to three and I think I will be there.
  95. #195
    Quote Originally Posted by jazzanova View Post
    i too would like to hear about this. i want to put this fork on my Blur TRC but the A-C of the 26" 150mm is ~532mm - too tall for the TRC. if i could drop this to ~522mm that'd be $$$
  96. #196
    Re: Pike 2014
    Quote Originally Posted by mattrwills View Post
    The 26" 150mm airspring assembly (RS Part#11.4018.026.003) which is the same assembly as a 120mm 29" Pike. The 140mm 29" airspring is the same as the 27.5 160mm Pike (RS Part#11.4018.026.001). BTI-USA doesn't have them in stock yet, but they are all on the website if your curious under "Rock Shox SoloAir Travel Adjustment Air Shafts"
    BTI | Suspension Fork Service Parts from Rock Shox (page 2)
  97. #197
    thanks. i spoke with a shop who called RS directly. he was told there isn't an airspring available to get 140mm on the 26" version. they did confirm it was in 'development and thought it would be available sometime this winter'...
    i hope that is the case although i'm confused on what needs to be 'developed'. seems to me something in the 26"/150mm spring needs to be shortened by 10mm.
  98. #198
    FWIW, I'm running a 150mm Pike 26" on my TRc and it feels sweeeeeeet! Sure, it's a few mm taller than my prior fork(s) but I'm also running more sag - IMO, it works out just fine. Best I can figure out, when on the bike/geared up, I'm riding about 10mm taller up front than their suggestion of 140mm travel. Been a couple weeks now, and it's riding fabulously.
    Now, the SC warranty department may have other ideas... However, I'm not at all worried about the frame integrity. I worry more about bashing and dragging the lower link on rocks than the head-tube area by a ginormous margin.
    Also figure their pro guys have used these frames as 4x and DS and DJ type frames (albeit with stock size forks AFAIK) riding them way, way harder, more aggressively, and abusively than anything my 150# skinny as will.
    I'd like to drop it down to 140mm as well, if/when a way comes about to do so, but am not too worried about it if not.
    Also about eventually swapping it to a 650b setup. New lowers for sure, sounds as if some of the internals as well, but maybe not all. Cost of those and doing the swap myself vs. buying an entirely new fork down the road...?
  99. #199
    Sep 2013
    Ski1970, its sounds similar to the what i have experienced with my 150 solo airs. If i apply front brake and slightly rock the the bike there is movement between the the stanchions and lower legs. If i then compress the fork let it extended back and then pick the front wheel up the lowers drop around 4mm. Its noticeable when riding too which is a little off putting! They have been back to tf tuned where i bought them, who then sent them back to Fishers (UK distributor) to look at. Just got them back two days ago after Fishers said they were "operating in away they would expect to see" ?? Still the same as they were before now i've got them back on the bike. Thought it may have been bit stiction but have cleaned & lubed the seals & still the same! Is this normal operating, i haven't experienced this with other forks. Anyone able to confirm this is as it should be??
  100. #200
    Jul 2013
    Could someone please check if;
    110-140 mm DUAL POSITION air in BLACK
    will be possible to get, or not?
    searched everything/where, found no answer...
  1. 2014 anyone?
    By druidh in forum Salsa
    Last Post: 08-08-2013, 07:08 PM
  2. Pike 2014 : End0 versus Chilly
    By gautama108 in forum Knolly
    Last Post: 06-27-2013, 04:58 AM
  3. 2014 When?
    By stygz1 in forum Specialized
    Last Post: 05-23-2013, 04:12 AM
  4. 2014 Pike Availability
    By Dazed in forum Shocks and Suspension
    Last Post: 05-10-2013, 06:24 AM
  5. Replies: 12
    Last Post: 04-25-2013, 04:07 PM
Members who have read this thread: 90
