    ... and if we just ... Old 2001 Manitou Answer Magnum R Replacement
    I've been looking around for a nice lightweight air shock to replace the '01 Manitou/Answer Magnum R on my Trek 6500. It's a 1-1/8" threadless, 80mm travel, 26" fork, v-brake bosses, and I am unable to find specs on the offset - but it does have an offset.
    It seems that the Manitou R7 Pro is the best option (the only option I can find) out there for an air shock with v-brake bosses - factory website specs say 38.1mm offset, whereas every other site says ZERO wheel center offset. I'm confused. Will there be a mis-match in offset be an issue? Does anyone know the offset specs on my old shock - I've searched and can only come up with the maintenance sheet.
    Thanks for any help guys/gals.
    Jul 2003
    Actually the R7 Pro is speced with a 38.1mm offset. Offset is added to a fork by either angling the crown, placing the dropouts on the front of the lowers, or a combination of both. Or in the case of ridged forks by curving the legs. Average offset for standard 9mm QR type forks is between 38 and 39mm. Unless you have found a truly unique R7, I doubt very seriously that it has 0 offset.
    Good Dirt
    Thanks Squash... The mis-information of 'ZERO' offset on all of the websites selling the R7's really threw me off. I'm assuming they just filled the data field with '0' by default.
    Jul 2003
    Quote Originally Posted by Gingerkid View Post
    Probably. If the forks have the dropouts mounted on the front of the lower legs you can be certain the fork has some offset. Most likely the retailer couldn't find the spec so entered 0. Very misleading IMHO. I'd be more inlcined to put UNK in there than 0. Less confusing at least. Or maybe the ought to hire a website manager that knows how to search for specs on the manufacturers website? That 38.1mm spec came straight off of Manitous site.
    Good Dirt
  1. Are the Manitou 3 springs on ebay compatible with a Manitou Magnum?
    By fernandoj in forum Vintage, Retro, Classic
    Last Post: 04-05-2010, 01:07 AM
  2. 2000 Manitou Magnum Help
    By Chip73 in forum Shocks and Suspension
    Last Post: 10-22-2009, 11:05 AM
  3. 2001 Manitou Supernova replacement parts?
    By Hack On Wheels in forum Shocks and Suspension
    Last Post: 07-02-2007, 11:09 PM
  4. Manitou magnum R
    By mrpercussive in forum Beginner's Corner
    Last Post: 05-02-2006, 11:17 PM
  5. HELP with old Manitou Magnum R rebuild
    By DakotaJockey in forum Shocks and Suspension
    Last Post: 02-26-2005, 03:29 AM
