    Reputation: CrozCountry's Avatar
    Mar 2011
    Oil and service for old Marzocchi fork (DJ1)
    Hi, I have a 2008 Marzocchi Dirt Jumper 1 coil/air, and I cannot find anywhere service instructions.
    Do you guys know where I can find the tech docs?
    I found this page:
    Tenneco Marzocchi Suspension
    • Is this page containing oil level or oil volume?
    • Are the two lines for DIRT JUMPER 1 - 100 TA and DIRT JUMPER 1 - 100 - TA - open bath two fork models, or two measurements for the damper leg (bath oil and splash oil)?
    • How do you measure oil level for a coil fork? Do you have to remove the coil while you check the oil level from the top?
    • Also oil level 10mm sounds too little, unless its mean oil 10cc oil volume, which make sense for splash oil.
    May 2015
    Did you find the info you needed? I have a 2009 Dj2 I want to service/oil change
    Mar 2011
    I found some info that seemed to be incorrect, it said to put quite a bit of oil in the damper side, and now the fork is very stiff and does not get much travel.
    B A N N E D
    Quote Originally Posted by CrozCountry View Post
    Marzocchi website has:
    100mm - left leg 150ml & right leg 155ml
    80mm - left leg 150ml & right leg 175ml
    A document from a old Marzocchi Service Center / Distributor has:
    100mm - left leg 50ml & right leg 155ml
    80mm - left leg 50ml & right leg 175ml
    Another Marzocchi Service Center / Distributor has:
    50ml in the left leg for the 80 & 100mm forks
    *There has been incorrect info shown on the Marzocchi website in the past.
  1. 2007 Marzocchi 66 Fork VS 2006 Marzocchi 66 Air Adaptor
    By jdiabolik in forum Downhill - Freeride
    Last Post: 02-24-2014, 11:44 AM
  2. Marzocchi MX Pro ETA 120mm Oil Service
    By hgg2k in forum All Mountain
    Last Post: 08-01-2013, 12:41 PM
  3. Marzocchi AM1 service/rebuild?
    By fiveo in forum Arizona
    Last Post: 09-18-2011, 08:46 PM
  4. Marzocchi 55 rc3 ti service instructions?
    By monstertiki in forum Shocks and Suspension
    Last Post: 08-11-2011, 05:26 PM
  5. Service 05 Marzocchi EXR Pro Air?
    By tenbsmith in forum Shocks and Suspension
    Last Post: 03-11-2011, 09:38 AM
