Results 1 to 2 of 2
    oil leaking from negative air chamber - big deal or not???
    Hi
    On my SJ FSR 29er - I have a Reba dual air fork. It was just rebuilt about less than 100 miles ago and was more stiff then before the rebuild. SO i just went in to lower the air pressures a bit and out of the negative chamber comes some oil.
    Now i can bottom out my fork by running over a 6 inch pot hole and pressing hard into the front fork -- where in the past it would not bottom so easily. I plan to ride later today but want to make sure this is not something major.
    I added some more air and it has stiffened up a little but still is soft - honestly it feels squishy and good and might ride good but i dont want too much of a bad thing. I think i always run it too firm anyway. But too much squish is going to lead to brake dive anyway.
    So is this a big deal? Yes i can take it back to the shop but then they will probably hold onto it for a week to get the job done.....
    Jan 2005
    all rebas will spit a little oil out of the negative valve it is assemble lube. If you want a softer fork you add air to negative side not let it out. follow the air pressure chart on the fork.
  1. Negative Chamber Question
    By lrehcazm in forum Shocks and Suspension
    Last Post: 05-27-2010, 01:23 PM
  2. Reba Negative chamber nut
    By blackflys64 in forum Shocks and Suspension
    Last Post: 07-18-2009, 09:53 AM
  3. OIL in Negative Air Chamber 04 Marathon SL
    By gecho4 in forum Shocks and Suspension
    Last Post: 02-10-2006, 06:51 PM
  4. Reba SL negative chamber leaking
    By NiC_MTB in forum Shocks and Suspension
    Last Post: 04-12-2005, 06:53 PM
  5. Marathon SL Leaking Negative Chamber
    By gearz in forum Shocks and Suspension
    Last Post: 12-22-2004, 11:43 AM
