Results 1 to 8 of 8
    Oil, cold and damping performance
    I recently did the fluid and seals in my Fox. The oil this time was 10wt. as opposed to the 7wt, I had been using. No real reason, just a matter of availability.
    I was riding yesterday in the low 30s F. Stopping at a pond to watch the sun and clouds on the water, I absent mindedly squished the fork and noticed the rebound was a good bit slower than normal.
    Obviously cold has an effect on viscosity, but I wouldn't think the low 30s would be cold enough. Am I wrong? How cold does it have to get before damping performance is altered?
    I'm just curious.
    "Bikes aren't fast--people are fast. Bikes are overpriced. It's an important distinction."---BikeSnob NYC
    Also, depends whether it's synthetic or not.
    Quote Originally Posted by GrantB
    I'm just curious.
    I doubt the cold is the significant factor. Most if not all shock oils have a very high viscosity index, meaning the viscosity does not change much with temp...(it of course still does)...
    The pour point of most shock oils is around -15F or so so colder...
    My fork starts to set up at about -10 C, the shock at about -15 C.
    Jun 2010
    I had the same problem with my dj3 fork. Granted a dj3 is not a high quality fork, and has grease instead of oil, at 30 degrees, the rebound is at least three times slower. Sorry I couldn't be of any assistance.
    www.derbyrims.com
    Reputation: derby's Avatar
    I feel the damping firmness change with about 20F degree differences, warmer or colder.
    Like every thing about suspension, some feel differences more than others. I feel the difference in my car's shocks in the morning when the temp drops below 45F or so.
    Reputation: Dougal's Avatar
    Do you know the oil brand?
    Whatever rockshox was using in the late 90's was noticably thicker approaching freezing. Replacing the same oil with the PJ1 and silkolene I was using at the time made a significant improvement in the cold while feeling similar in the warm.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    I don't know the make of the oil. It is in a Fox branded bottle, marked 10w.
    waiting for a piece (.45)
    Reputation: SpecialWarr's Avatar
    In with derby... I notice a change in flow quality at about that change in temperature....
