I am looking to upgrade parts on my 2011 Fuji Nevada 1,0 and i am thinking of starting with the forks, the bike currently has SR Suntour XCM fork 100mm. What would you guys recommend? I am leaving a list of all the components of the bike below. What else would yo recommend switching out for a better ride. i ride all mountain mostly i want something lightweight right now the bike is over 30 pounds in weight. Thanks for the advice and do you think its worth upgrading the bike rather than spending 1500+ on a new bike i was looking into canfield build but thinking of upgrading this. Here's the part listing:
Fuji
Product name Nevada 1.0
Features -Fuji A1-SL alloy frame
-SR Suntour XCM fork 100mm
-Shimano Alivio 27-speed
-Tektro Draco hydro disc brakes
Colour Matte Black
Frame size 15", 17", 19", 21", 23"
Frame Fuji A1-SL Aluminum with PowerCurve down tube, Tri shaped top tube, Oversized seat tube and integrated head tube, double water bottle mounts
Rear Triangle Fuji A1-SL aluminum with S-bend stay, Cold forged dropout and disc mount w/replaceable hanger
Fork SR Suntour XCM, 100mm Travel w/Mechanical LO
Crankset Shimano Alivio 22/32/44T
B/bracket Sealed Cartridge Bearing ST
Pedals Wellgo ATB w/steel cage
Front derailleur Shimano Alivio, 34.9mm
Rear derailleur Shimano Alivio SGS Top Normal, 9sp
Shifters Shimano Alivio Rapid Fire, 27-speed
Cassette Shimano Cassette, 11-34T 9sp
Chain Shimano HG-53
Wheels Fuji Custom Disc, IS 32H hubs, Fuji Double Wall Al Disc rims
Tyres Kenda K-837F/K-848R ATB, 26 x 2.1" Wire Bead
Brakes Tektro Draco Hydraulic Disc, 180/160mm rotor
Brake levers Tektro Draco Hydraulic Disc Brake Lever
Headset Fuji Custom 1 1/8" Press Fit Integrated, 30mm spacers
Handlebar Fuji Riser 20 Alloy Riser Bar
Stem Fuji Forged Alloy w/removable faceplate
Grips Fuji Dual Density Kraton rubber
Saddle Fuji Sport MTB w/ steel rail
Seatpost Fuji Alloy micro-adjust, 350x31.6mm
Actual Weight 14.02kg
Year 2011
Results 1 to 1 of 1
Hot DealsContestsLatest Mountain Bike ArticlesVideosMTBR on Facebook |
LinkBack URL
About LinkBacks
