• 09-28-2012
    New Shocks for Fuji Nevada 1.0 ?
    I am looking to upgrade parts on my 2011 Fuji Nevada 1,0 and i am thinking of starting with the forks, the bike currently has SR Suntour XCM fork 100mm. What would you guys recommend? I am leaving a list of all the components of the bike below. What else would yo recommend switching out for a better ride. i ride all mountain mostly i want something lightweight right now the bike is over 30 pounds in weight. Thanks for the advice and do you think its worth upgrading the bike rather than spending 1500+ on a new bike i was looking into canfield build but thinking of upgrading this. Here's the part listing:
    Product name Nevada 1.0
    Features -Fuji A1-SL alloy frame
    -SR Suntour XCM fork 100mm
    -Shimano Alivio 27-speed
    -Tektro Draco hydro disc brakes
    Colour Matte Black
    Frame size 15", 17", 19", 21", 23"
    Frame Fuji A1-SL Aluminum with PowerCurve down tube, Tri shaped top tube, Oversized seat tube and integrated head tube, double water bottle mounts
    Rear Triangle Fuji A1-SL aluminum with S-bend stay, Cold forged dropout and disc mount w/replaceable hanger
    Fork SR Suntour XCM, 100mm Travel w/Mechanical LO
    Crankset Shimano Alivio 22/32/44T
    B/bracket Sealed Cartridge Bearing ST
    Pedals Wellgo ATB w/steel cage
    Front derailleur Shimano Alivio, 34.9mm
    Rear derailleur Shimano Alivio SGS Top Normal, 9sp
    Shifters Shimano Alivio Rapid Fire, 27-speed
    Cassette Shimano Cassette, 11-34T 9sp
    Chain Shimano HG-53
    Wheels Fuji Custom Disc, IS 32H hubs, Fuji Double Wall Al Disc rims
    Tyres Kenda K-837F/K-848R ATB, 26 x 2.1" Wire Bead
    Brakes Tektro Draco Hydraulic Disc, 180/160mm rotor
    Brake levers Tektro Draco Hydraulic Disc Brake Lever
    Headset Fuji Custom 1 1/8" Press Fit Integrated, 30mm spacers
    Handlebar Fuji Riser 20 Alloy Riser Bar
    Stem Fuji Forged Alloy w/removable faceplate
    Grips Fuji Dual Density Kraton rubber
    Saddle Fuji Sport MTB w/ steel rail
    Seatpost Fuji Alloy micro-adjust, 350x31.6mm
    Actual Weight 14.02kg
    Year 2011
