Results 1 to 5 of 5
    steel is real...heavy
    New fork out of the box...coated in oil?
    Hey guys...just unboxed my new fork out of the retail box. Bought it from a reputable online retailer. It has a really thin coating of oil on it, especially on the crown and stanchions.
    I've never bought a retail boxed fork before...I'm guessing this is not normal, but need a sanity check from you guys. What do you think?
    South Central PA
    Reputation: 11053's Avatar
    normal
    wipe it down and go ride
    if you have a seal problem, it will show up quickly as soon as you hit the trail.
    Quote Originally Posted by Norman Clydesdale View Post
    normal
    I have purchased over a dozen new forks and only a couple had residue in small areas. I'd have some concern.
    Reputation: trailbildr's Avatar
    Dec 2004
    Wipe it down and go. Check your rebound/compression settings to see if they work at the extremes. If no, pull dampers and put in correct amount of oil. Then commence lamenting the state of OEM assembly in Asia and the requisite boat trip to the US.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Quote Originally Posted by jvp108 View Post
    I had this happen with a 2012 rockshox revelation xx wc. Turning lock out off didn't do anything. Sent it back to SRAM for warranty and it came back working and then got worse and worse. Took it in for service at lbs they said it was ok. Took it to a specialist they found it was a leak in the lever. SRAM charged me $80 for a new one. Fork works now though.
    So yeah if it's covered in oil it could be a problem.
  1. Ceramic coated DUC32
    By Jon Richard in forum Maverick
    Last Post: 04-10-2013, 11:14 AM
  2. can fork uppers be re-coated?
    By terrible in forum Shocks and Suspension
    Last Post: 08-17-2012, 01:12 PM
  3. ceramic coated rims.....
    By veintinueve in forum 27.5
    Last Post: 05-13-2012, 12:57 PM
  4. powder coated frames
    By drivengsxr1000 in forum Frame Building
    Last Post: 12-05-2011, 06:19 PM
  5. powder coated my paradox
    By playdead in forum Banshee Bikes
    Last Post: 07-17-2011, 07:29 AM
