need to remove my star nut
I need to know how to remove the star nut from my fork and i need to know what tools to use. It would really be helpful if i cold find out how to remove the star nut from the top of the fork, I dont want to pound it through the bottom of the fork. thanx
Drill the middle out of it first. Make sure you don't bind up the bit and spin the whole nut inside the steerer because that'll totally gouge it. After the middle piece is gone you should be able to break apart or bend together the actual "star" pieces and pull it out the top. And you may want to put some tape or rags over the wipers on your fork while drilling to keep the shavings from getting to them.
Another way
Another clean alternative is to use an extra pipe that just fits inside the steerer tube. Slide the smaller pipe into the steerer tube from the bottom and pound the star nut into that pipe. Once the star nut is in the smaller pipe, you can slide out the pipe along with the nut. It may be hard to find a "trash" pipe that just fits into the steerer tube though.
thats a good idea but i am trying to remove it from a sid race carbon, so there is no hole at the bollom of the crown, i guess i will just have to be really careful tryin to drill it out so i wont dammage the steerer tube.
Just pound that focker
in a little farther till it's out of the way and insert another star nut or one of those starless type top caps
Make sure you REALLY want that thing out of there because you are likely to trash the inside of the tube trying to get the star nut out. I struggled with one for a long time doing the drill-the-center-out thing (no go, the center sleeve just spun) and tried to use a hole-saw to mill the arms off the star (spring steel: no-can-saw-through). I ended up pulling it out by cranking the heck out of the top cap. Not pretty.
Good luck.
simply me
The carbon steerer was NOT designed for starnut use, it should have a compression plug. The scratches left on the steerer tube when the star nut was inserted may well have damaged the carbon... use caution! and next time RTFM!
theHeadlessThompsonGunner
Pardon my ignorance, but I thought carbon steerer tubes were under no circumstances to be used with starnuts!? Isn't the idea that just the presence of the starnut will place stress risers and undue pressure on an already fragile part? So, pounding it in further will just move the stress riser further down, and weaken the whole deal even more...
MY recommendation would be not to ride that fork in its current condition. It doesn't sound even remotely safe to me. I also hope you're not trying to get the starnut out before selling it to an unexpecting buyer....
"I've courted brain damage like some courtesan of darkness."
-The Good Doctor
no starnuts in carbon steerers. expander plugs only.
definitely drill yours out, don't tear up the inside of the steerer any more than it already is.
its not my fault that it is in the steerer, i had it installed on my bike by a bike store and now the bike store has gone out of business. I want to get it out and put an expander plug in and i an trying to find the easiest way to remove the star nut.
I guess I'm not too surprised! If I were you, I'd take it to the best shop you know of (but be a better judge this time, eh?) and see what they have to say. Don't go at it with a hammer and screwdriver at home - perhaps a faithful LBS mech can find a good, clean way to take it out, and then properly evaluate whether you're putting any hopes of having children at risk by riding it.
Unfortunately, I don't know of any such shops in the Tennessee area, but someone on the local forums might. Don't take your chances any more though - carbon can be unpredictable at best and maiming at worst when not taken care of...
-The Good Doctor
Some friendly tips from a bike shop mechanic
try a blended method:
use the pipe but it need only be 2" in length and find a 3" or 4" bolt that threads into the star nut and drill a hole in a block of metal or use a stack of washers or a metal top cap and crank on that star nut through the top with the bolt threaded into it.
this should do the least damage if any at all, since the pipe will serve to retract the wings of the star fangled nut as it enters the pipe.
this might take a litle grunt but will be the nicest to your steerer
one caveat: be careful to do this slowly and check to see if the spring steel itself is flexing and that the wings are not expanding as you turn it inside out, if expanding stop because it will split your steerer
Maybe if you're nice and explain your situation to
Rock Shox they'll do it for you or replace the steerer tube if necessary....I sure as hell wouldn't take risks with scratched carbon...you might have only been lucky so far (in the original installation not having caused failure yet).
suum quique
How on earth do you people stumble across a thread which died out on April 26th, 2004 and then decide it's time to reply almost 8 MONTHS later? What are your forum thread sort settings???
By not looking, of course
it's pissedoffwookie's fault.
suum quique
I know this thread is old, but... was it a Trek dealer? I am assuming you screen name is based on your riding a Fuel. In that case I suggest you find the next Trek dealer and talk to them, I think Trek should be willing to send you a new fork or if possible put a new steerer in that fork. No way would they want to risk it failing based on what a authorized dealer did.
modify star nut before install.....
I got smart, i think, and I remove one star from the assembly before installation. This leaves one star and the threaded stud. I install as usual. It seems to hold just fine, enough to preload the headset. To remove, just tap the star nut sideways and pull out from the top. Always works for me on my Ti fork, closed at the bottom.
Now that the thread's revived just what
was the outcome of the situation, fuel36?
suum quique
Why don't you just leave it in? If needed, you can always tap it down a little further to fit the compression plug in, but taking out could only serve to damage the steerer tube.
Need to remove my star nut.
Won't your one get lonely?
Velodramatic
just got two sid carbon crwons. anybody knows how to get the expander plug a little deeper into the steerer? gotta shorten the steerer tube.... do i just tap on the cap? i'm afarid of ruining the carbon
Skinny guys fight 'til they're burger
Velodramatic
ok, already solved: just tap it slightly, and everything comes apart.
By Philo Beddoe in forum General Discussion
Last Post: 04-19-2004, 10:24 PM
By dawgcatching in forum Brake Time
Last Post: 03-29-2004, 08:50 AM
By cwr3 in forum Singlespeed
Last Post: 03-02-2004, 10:13 AM
By EndoLookout in forum Shocks and Suspension
Last Post: 01-24-2004, 11:46 AM
By SuperBad in forum Singlespeed
Last Post: 01-21-2004, 06:41 PM
- You may not post replies
- You may not edit your posts
Forum Rules
