Need knowledge on 2003 Cannondale Jekyll rear shock
I am building a 2003 Cannondale Jekyll. I have a Fox Float RL Propedal rear shock for it. When I bought the shock, it said it was for my generation frame, from all of the pics I can find, it looks to be correct. But, when I test fit the shock in between the forward shock mounts and the frame, there is roughly 2 to 3mm of play on each side of the shock mounts and the frame. Is this how it is designed? I just can't seem to find a good enough pic anywhere that allows me to see if it is normal or if I have the wrong shock. If it is the correct shock, where may I find the bolts to mount the shock? Any help would be much appreciated. Thanks.
Are you sure you have a Jekyll II ? The switch from Jekyll I to Jekyll II was in 2003 if I remember correctly - and the Fox Float RL Pro Pedal only fits the Jekyll II.
I have a Jekyll II 2000 with this rear shock, can send you some pics if you want - ?
Here are a few pics of what ive got.
Here are a few pics that may help with finding out if what I have is the right shock for my frame.
In one pic you can see a few millimeters of clearance on each side of the shock mounts and the
frame. I just wasn't sure if this was normal or not. Thanks a lot. This is my first time posting pics, so I hope they post.
This is definitely a Jekyll II Frame, so the rear shock should fit. But maybe the bushings and bolts are not for / from a Jekyll. Other manufacturers like Corratec also used this Special design - or they are just worn out. Resolution of the pics is too low to say :-(
The original mounting bolts and bushings can be purchased separately, please have a look on page 29 of the linked pdf.
A cannondale dealer should be able to get These parts for you..
http://digidownload.libero.it/thebik...Supplement.pdf
thatīs what you Need (hopefully theupload worked)! :-)
Just heard Cannondale has stopped manufacturing these parts before some years, so it could be difficult to get them..
Yes, that is exactly what I need. My frame already has the bushings, so I'll be on the hunt for the bolts. Thanks a lot for your help!
btw: thatīs what it might look like when you are done ! ;-)
By akaBrowntown in forum Specialized
Last Post: 03-22-2013, 05:03 PM
By noxx in forum Cannondale
Last Post: 04-05-2012, 11:35 AM
By 1spd1way in forum Cannondale
Last Post: 03-30-2011, 07:27 AM
By Biohazard74 in forum Trek
Last Post: 01-14-2011, 12:04 PM
By Biohazard74 in forum Shocks and Suspension
Last Post: 01-13-2011, 01:43 PM
- You may not post replies
- You may not edit your posts
Forum Rules
