Results 1 to 2 of 2
    Reputation: umassracer's Avatar
    New question here. Need HELP w/Enduro Seals on 02' Duke Race
    Hello all,
    I just decided to revamp/rebuild my duke fork since it was NOS 2 seasons back, and I could use any...all help with installing new Enduro seals on this 2002 Duke race. I can't seem to find any info on this install let alone if I should re-install the foam rings. Can the Endro dust seal kit be installed w/out using an official 30mm dust seal install tool? Thanks to all for any help you may give
    PS: For such a basic fork, the bushing replacement looks like a tons of fun w/out the bushing setter tool...I can't wait
    Good luck on the bushing toolless work, if they are set the wrong depth new lowers could be needed!!!!!!!!!! Just use a 32mm socket to press in the new seals works great, wipe a small grease film on the seal to help install it.A film of grease not a handful, little is needed, get some racetech seal grease from a Moto shop near you. I prefer to use no foam rings in RShox forks.If you need more help email isotuned@yahoo.com it is easy.
