Results 1 to 3 of 3
    May 2013
    Need help with rock shox mounting hardware!!
    I just bought a vivid air for my 2012 RM Slayer 70 i have no idea what size mounting hardware i need. if anybody knows this i would appreciate the info.
    Reputation: trailbildr's Avatar
    Dec 2004
    You'll have to measure it, of course... Measure the distance between the mounting tabs, top and bottom. These measurements (plus the ID of the bolts you have) will give you the numbers. 8x42 means you have a bolt that is 8mm and 42mm between your mounting tabs. Could be 6mm or 10mm ID and many different widths. Get some digital calipers and measure to the nearest 1/10th of a mm. Tell your local bike shop to use QBP and they should be able to get what you need.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    May 2013
    I did do some measuring but i guess i really didnt know what i was doing..lol! Thanks for the info.
  1. rock shox mounting hardware
    By dimitrin in forum Shocks and Suspension
    Last Post: 09-18-2015, 05:10 PM
  2. fox dhx rc4 mounting hardware
    By dave_128 in forum All Mountain
    Last Post: 03-12-2012, 05:13 PM
  3. Fox Rear Shox Mounting Hardware Kit for RIP 9
    By Robson13 in forum Niner Bikes
    Last Post: 10-16-2011, 01:38 PM
  4. Rock Shox Domain 302 vs Rock Shox Lyric
    By bome in forum Shocks and Suspension
    Last Post: 05-24-2011, 08:34 AM
  5. Rock Shox and Fox shocks: Same mounting hardware??
    By kapusta in forum Shocks and Suspension
    Last Post: 05-09-2011, 03:07 PM
