    Sep 2004
    Need help finding mounting hardware - 2006 Mongoose Teocali Comp
    I recently purchased a 2006 Mongoose Teocali Comp frame when Nashbar had them on clearance. It was a great find...below is a link to the frame:
    BikePedia - 2006 Mongoose Teocali Comp Complete Bicycle
    I recently purchased a 2010 Manitou ISX-1 Air Shock (190 x 50mm) for this frame. However, I am having an impossible time finding the mounting hardware for this shock for the frame. Has anyone found mounting hardware for this frame? I was told by the tech guy at that the frame requires 8x19 spacers and 6x19 spacers. Thoughts on where to find these parts for a manitou shock? Or any ideas on a work around.
    I appreciate your input as I seem to have exhausted my resources.
    Thanks.
    Reputation: mullen119's Avatar
    I was able to reuse the existing mounting hardware on my Teocali. If that doesnt work and you have some fabricating ability, I would buy a longer size that is more common and cut them down. I had to do that for a friend and it wasnt to bad.
    Reputation: Cobra8d's Avatar
    Aug 2010
    These guys have M8x20 and M6x18, might fit. Or you might have file one and add a spacer to the other.
    Manitou 12 5mm Eyelet Shock Mount Hardware M8x38 0mm | Joyride Cycles
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    contact/Google the Path in Tustin CA they will either have it or get them for U
